Ir para o conteúdo principal
Nintendo WaveBird Wireless Controller C-Stick Replacement
O que você precisa
  1. Nintendo WaveBird Wireless Controller C-Stick Replacement, Batteries: passo 1, imagem 1 %32 Nintendo WaveBird Wireless Controller C-Stick Replacement, Batteries: passo 1, imagem 2 %32
    • Pull down on the battery cover release lever and pull back to remove the cover.
    Pergunte ao FixBot
    Comentar
  2. Nintendo WaveBird Wireless Controller C-Stick Replacement: passo 2, imagem 1 %32
    • Remove both batteries from the device.
    Pergunte ao FixBot
    Comentar
  3. Nintendo WaveBird Wireless Controller C-Stick Replacement, Front Panel: passo 3, imagem 1 %32 Nintendo WaveBird Wireless Controller C-Stick Replacement, Front Panel: passo 3, imagem 2 %32
    • Remove the eight 9 mm screws from the back panel using the Tri-point Y1 screwdriver.
    • During reassembly, firmly hold the panels of the controller together while replacing the screws so the panels do not separate.
    Pergunte ao FixBot
    Comentar
  4. Nintendo WaveBird Wireless Controller C-Stick Replacement: passo 4, imagem 1 %32 Nintendo WaveBird Wireless Controller C-Stick Replacement: passo 4, imagem 2 %32
    • Carefully turn over the controller and place it on a flat surface.
    • Slowly separate the top panel from the bottom panel.
    • The buttons are loose and may fall off the motherboard.
    • Once separated, set aside the top panel.
    • During reassembly, make sure the front panel lines up with the buttons so they slide back into place.
    Pergunte ao FixBot
    Comentar
  5. Nintendo WaveBird Wireless Controller C-Stick Replacement, Buttons: passo 5, imagem 1 %32 Nintendo WaveBird Wireless Controller C-Stick Replacement, Buttons: passo 5, imagem 2 %32 Nintendo WaveBird Wireless Controller C-Stick Replacement, Buttons: passo 5, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Use tweezers to remove the buttons.
    • It may be easier to remove the A button off of the pad by lifting it with your fingers.
    • During reassembly, make sure all buttons are in their respective sockets so they match up with the front panel.
    Pergunte ao FixBot
    Comentar
  6. Nintendo WaveBird Wireless Controller C-Stick Replacement, C-Stick: passo 6, imagem 1 %32 Nintendo WaveBird Wireless Controller C-Stick Replacement, C-Stick: passo 6, imagem 2 %32
    • Potential for device damage: Rough handling of the C-stick could cause the daughterboard to break off of the motherboard.
    • Grab the base of the yellow C-Stick cover with one hand and gently hold down the bottom piece of the motherboard with the spudger.
    • Pull off the yellow C-Stick cover.
    • During reassembly, make sure the slots inside the C-Stick cover line up with the motherboard so it can fit back together.
    Pergunte ao FixBot
    Comentar
Conclusão
3 outras pessoas executaram este guia.
Equipe
Cal Poly, Team 10-40, Amido Spring 2013 Membro de Cal Poly, Team 10-40, Amido Spring 2013
CPSU-AMIDO-S13S10G40
4 Membros
Autoria de 37 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 8
Últimos 30 dias: 51
Ao todo: 3,005
