Ir para o conteúdo principal
Nintendo WaveBird Wireless Controller Buttons Replacement
O que você precisa
  1. Nintendo WaveBird Wireless Controller Buttons Replacement, Batteries: passo 1, imagem 1 %32 Nintendo WaveBird Wireless Controller Buttons Replacement, Batteries: passo 1, imagem 2 %32
    • Pull down on the battery cover release lever and pull back to remove the cover.
    Pergunte ao FixBot
    Comentar
  2. Nintendo WaveBird Wireless Controller Buttons Replacement: passo 2, imagem 1 %32
    • Remove both batteries from the device.
    Pergunte ao FixBot
    Comentar
  3. Nintendo WaveBird Wireless Controller Buttons Replacement, Front Panel: passo 3, imagem 1 %32 Nintendo WaveBird Wireless Controller Buttons Replacement, Front Panel: passo 3, imagem 2 %32
    • Remove the eight 9 mm screws from the back panel using the Tri-point Y1 screwdriver.
    • During reassembly, firmly hold the panels of the controller together while replacing the screws so the panels do not separate.
    Pergunte ao FixBot
    Comentar
  4. Nintendo WaveBird Wireless Controller Buttons Replacement: passo 4, imagem 1 %32 Nintendo WaveBird Wireless Controller Buttons Replacement: passo 4, imagem 2 %32
    • Carefully turn over the controller and place it on a flat surface.
    • Slowly separate the top panel from the bottom panel.
    • The buttons are loose and may fall off the motherboard.
    • Once separated, set aside the top panel.
    • During reassembly, make sure the front panel lines up with the buttons so they slide back into place.
    Pergunte ao FixBot
    Comentar
  5. Nintendo WaveBird Wireless Controller Buttons Replacement, Buttons: passo 5, imagem 1 %32 Nintendo WaveBird Wireless Controller Buttons Replacement, Buttons: passo 5, imagem 2 %32 Nintendo WaveBird Wireless Controller Buttons Replacement, Buttons: passo 5, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Use tweezers to remove the buttons.
    • It may be easier to remove the A button off of the pad by lifting it with your fingers.
    • During reassembly, make sure all buttons are in their respective sockets so they match up with the front panel.
    Pergunte ao FixBot
    Comentar
Conclusão
6 outras pessoas executaram este guia.
Douglas
Membro desde: 04/15/13
62 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 10-40, Amido Spring 2013 Membro de Cal Poly, Team 10-40, Amido Spring 2013
CPSU-AMIDO-S13S10G40
4 Membros
Autoria de 38 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 11
Últimos 30 dias: 64
Ao todo: 4,282
