Ir para o conteúdo principal
Nintendo Switch Rear Panel Replacement
O que você precisa
  1. Nintendo Switch Rear Panel Replacement, Release the Joy Con controller locking tabs: passo 1, imagem 1 %32 Nintendo Switch Rear Panel Replacement, Release the Joy Con controller locking tabs: passo 1, imagem 2 %32 Nintendo Switch Rear Panel Replacement, Release the Joy Con controller locking tabs: passo 1, imagem 3 %32
    • Before you begin this repair, make sure the device is completely powered off.
    • Press and hold down the small round button on the back of the Joy Con controller.
    • While you hold down the button, slide the controller upward.
  2. Nintendo Switch Rear Panel Replacement, Remove the Joy Con controllers: passo 2, imagem 1 %32 Nintendo Switch Rear Panel Replacement, Remove the Joy Con controllers: passo 2, imagem 2 %32 Nintendo Switch Rear Panel Replacement, Remove the Joy Con controllers: passo 2, imagem 3 %32
    • Continue sliding the Joy Con upward until it's completely removed from the console.
    • Repeat this same process for the other Joy Con.
  3. Nintendo Switch Rear Panel Replacement, Remove the back-side screws: passo 3, imagem 1 %32
    Ferramenta utilizada neste passo:
    Magnetic Project Mat
    $16.96
    • Use a Y00 screwdriver to remove the four 6.3 mm-long screws securing the rear panel.
    • If you do happen to strip one of the four 6.3 mm-long Y00 screws, If you are lucky and careful, you may be able to use a Y0 bit to remove the screw(s). Please note that if you do attempt this, a bit of extra pressure will need to be applied to the screwdriver so that the screwdriver bit catches the screw.
    • If you do end up removing the stripped screw with this method, PLEASE do not reuse the screw again and instead replace the screw.
  4. Nintendo Switch Rear Panel Replacement, Remove the top and bottom screws: passo 4, imagem 1 %32 Nintendo Switch Rear Panel Replacement, Remove the top and bottom screws: passo 4, imagem 2 %32
    • Use a JIS 00 driver to remove the following screws securing the rear panel:
    • One 2.5 mm-long screw on the top edge of the device
    • Two 2.5 mm-long screws on the bottom edge of the device
    • To prevent these tight screws from stripping, apply firm downward force, work slowly, and try another JIS 00 driver if the screws won't come out. Make sure the driver is fully inserted.
    • You can use a Phillips #000 screwdriver in a pinch, but you risk damaging or stripping the screws. Push down firmly on the screwdriver and twist slowly. Often, switching drivers may help, even if they are the same size.
  5. Nintendo Switch Rear Panel Replacement, Remove the center side screws: passo 5, imagem 1 %32 Nintendo Switch Rear Panel Replacement, Remove the center side screws: passo 5, imagem 2 %32
    • Use a JIS 00 driver to remove the two 3.8 mm center screws on the sides of the device (one on each side).
  6. Nintendo Switch Rear Panel Replacement: passo 6, imagem 1 %32 Nintendo Switch Rear Panel Replacement: passo 6, imagem 2 %32
    • Use your finger to flip up the kickstand on the back of the device.
    • If there's a microSD card in the microSD card slot, remove it now before you continue to the next step.
  7. Nintendo Switch Rear Panel Replacement, Remove the kickstand well screw: passo 7, imagem 1 %32
    • Use a JIS 00 driver to remove the 1.6 mm screw in the kickstand well.
    • Close the kickstand.
  8. Nintendo Switch Rear Panel Replacement, Remove the rear panel: passo 8, imagem 1 %32 Nintendo Switch Rear Panel Replacement, Remove the rear panel: passo 8, imagem 2 %32 Nintendo Switch Rear Panel Replacement, Remove the rear panel: passo 8, imagem 3 %32
    • Open the game card cartridge flap.
    • The game card cartridge flap attaches to the other half of the plastic shell, preventing you from completely lifting up the rear panel if it's closed.
    • Lift the rear panel up from the bottom of the device and remove it.
Conclusão
Compare your new replacement part to the original part. You may need to transfer remaining components from the new part before installing.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Nintendo Switch Answers community for help.
89 outras pessoas executaram este guia.
Craig Lloyd
Membro desde: 02/10/16
41.056 Reputação
Autoria de 82 guias
11Comentários do guia
Excellent and concise guide.
The new panel doesn’t come with the sticky grille pieces x 2 on the bottom. Is it supposed to be a straight transfer between the old and the new?
fclbriat123 - Responder
You can transfer the grill to the new back plat
Phillip Norton -
Just did this replacement and there are a few things to keep in mind that this review does not mention. There are x2 square foam pieces that can be transferred to the new panel located at the bottom backside of the old. Also, the game cartridge shield hardware and the kickstand holder hardware have to be taken off the back of the old panel and transferred to the new panel. The kickstand has 2 Phillips #000 screws and the game cartridge shield has 1 Phillips #000 screw
Ryan Talbert - Responder
How do you transfer the foam pieces? Use some heat to loosen their adhesive and then remove them and transfer over the new backplate?
John - Responder
Is the casing the same between the HAC model and the HAD model? This guide doesn’t specify
Julian Webb - Responder
Comentar
Visualizações:
Últimas 24 horas: 54
Últimos 7 dias: 347
Últimos 30 dias: 1,396
Ao todo: 120,513
