Introdução
Follow this guide to replace the power and volume button board inside of a Nintendo Switch gaming console.
The Switch uses JIS screws. A JIS 00 driver works best, but you can also use a JIS 000 driver. If you use a Phillips driver, you'll risk stripping the screws.
Note: This guide, and the part we sell, are compatible with the original Nintendo Switch model released in 2017, as well as the newer refreshed model released in 2019 (model numbers HAC-001 and HAC-001(-01), respectively).
O que você precisa
Press and hold down the small round button on the back of the Joy Con controller.
While you hold down the button, slide the controller upward.
Continue sliding the Joy Con upward until it's completely removed from the console.
Ferramenta utilizada neste passo:Magnetic Project Mat$19.95
Use a Y00 screwdriver to remove the four 6.3 mm-long screws securing the rear panel.
Use a JIS 00 driver to remove the following screws securing the rear panel:
One 2.5 mm-long screw on the top edge of the device
Two 2.5 mm-long screws on the bottom edge of the device
Use a JIS 00 driver to remove the two 3.8 mm center screws on the sides of the device (one on each side).
Use a JIS 00 driver to remove the 1.6 mm screw in the kickstand well.
Close the kickstand.
Open the game card cartridge flap.
Lift the rear panel straight up from the bottom of the device and remove it.
Use a JIS 00 driver to remove the six 3 mm screws securing the shield plate to the device.
Ferramenta utilizada neste passo:iFixit Thermal Putty$9.95
Insert a spudger underneath the shield plate along the edge of the device.
Pry up to lift the shield plate and remove it from the device.
During reassembly, if you don't have replacement thermal compound, use the flat end of a spudger to distribute the old compound evenly across the heat pipe, as thick as possible to ensure proper contact. Repeat this process on the shield plate.
If you need to replace it, refer to our thermal paste guide to remove the old thermal compound and replace it with an appropriate compound, such as thermal putty or K5 Pro, during reassembly.
Use the point of a spudger to pry the battery connector straight up and out of its socket on the motherboard.
Use a JIS 00 driver to remove the three 3 mm screws securing the heat sink to the motherboard.
Ferramenta utilizada neste passo:iFixit Adhesive Remover$19.99
Carefully peel the two foam pieces stuck over both the heatsink and the fan away from the fan.
If you have some, dip the point of a spudger in adhesive remover or isopropyl alcohol (90% or greater).
Insert the point of a spudger underneath a part of the foam that isn't stuck to anything.
Press the top of the foam with your finger to hold it in place.
Roll the spudger tip underneath the foam all the way to the other end of the foam to release it.
Use an opening tool, spudger, or your fingernail to flip up the small, hinged locking flap on the fan cable ZIF connector.
Use a spudger to flip up the small black locking flap on the power/volume ribbon cable ZIF connector.
Ferramenta utilizada neste passo:Tweezers$4.99
Remove the power/volume board with a pair of blunt nose tweezers.
16 outras pessoas executaram este guia.
8Comentários do guia
Great guide. Just repaired my daughters Switch by replacing power button.
I replaced the cable and still have the same issue, volume up button don't work and volume down is volume up, and it's always kn
Hi, did you manage to fix it? I have the exact issue
I changed the cable and it works.
Thanks
Great guide. There were a couple of steps I found missing, but the rest of the guide had very similar steps, so just applying the same logic to the mini-boards I had to pull worked perfectly. This guide saved me from having to buy a new switch or pay almost the price of a new one to have it repaired!
