Introdução
Use this guide to replace the shield plate and both Wi-Fi antennas in your Nintendo Switch OLED.
The Switch OLED uses JIS screws, but you can use a Phillips screwdriver in a pinch. Be very careful not to strip the screws. iFixit's Phillips bits are designed to be cross-compatible with JIS-style screws.
Note: When you remove the shield plate, you’ll need to replace the thermal compound between the plate and the heatsink. Normal thermal paste isn't designed to bridge large gaps, so you'll need thermal putty or viscous thermal paste.
O que você precisa
Press and hold down the small round button on the back of the Joy Con controller.
While you hold down the button, slide the controller upward.
Continue sliding the Joy Con upward until it's completely removed from the console.
Use a Phillips driver, or a JIS driver, to remove the 2 mm-long screw securing the top of the rear case to the frame.
Use a Phillips driver to remove the two 2 mm-long screws securing the bottom of the rear case to the frame.
Use a Phillips driver to remove the 3.8 mm screw securing the right Joy-Con sensor rail to the rear case.
Use a Phillips driver to remove the 3.8 mm screw securing the left Joy-Con sensor rail to the rear case.
Use your finger to flip up the kickstand on the back of the device.
Use a Y00 screwdriver to remove the two 4.3 mm screws securing the rear case to the frame.
Use the flat end of a spudger to separate a corner of the tape from the shield plate.
Use tweezers, or your fingers, to pull up and disconnect the primary Wi-Fi antenna's coaxial cable.
Use tweezers, or your fingers, to reroute the primary antenna's coaxial cable out of its slots in the shield plate.
Use a Phillips driver to remove the two 4.4 mm screws securing the primary Wi-Fi antenna to the shield plate.
Insert an opening pick between the primary Wi-Fi antenna and the shield plate.
Pry up with the pick to separate the primary Wi-Fi antenna from the shield plate.
Use tweezers, or your fingers, to pull up and disconnect the secondary Wi-Fi antenna's coaxial cable.
Use the point of a spudger to reroute the secondary Wi-Fi antenna's coaxial cable from its slot in the frame.
Use a Phillips driver to remove the 4.4 mm screw securing the secondary Wi-Fi antenna to the shield plate.
Insert an opening pick between the secondary Wi-Fi antenna and the shield plate.
Pry up with the pick to separate the secondary Wi-Fi antenna from the shield plate.
Use a Phillips driver to remove the six 4.4 mm screws securing the shield plate to the frame.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Nintendo Switch OLED Answers community for help.
Uma outra pessoa concluiu este guia.
3Comentários do guia
My question is, where do I get replacement screws? Are the shield screws the same size as the regular switch?
Hi Ren.
Unfortunately, we don't sell the screws alongside the replacement shield. The regular Switch has different screws as well, but you might find some on eBay. I'm not sure how effective Nintendo's customer service is here, but you could give it a shot to find out the type of screws.
Where do I even by the oled heat plate from I keep finding normal switch or this %#*@ tutorial
