Ir para o conteúdo principal
Nintendo Switch Lite Battery Disconnection
Pré-requisito somente
Este é um guia somente para pré-requisitos! Este guia faz parte de outro procedimento e não deve ser usado sozinho.
O que você precisa
  1. Nintendo Switch Lite Battery Disconnection, Remove the back panel screws: passo 1, imagem 1 %32
    Ferramenta utilizada neste passo:
    Magnetic Project Mat
    $19.95
    • Before beginning this repair, make sure that the device is completely turned off.
    • Use a Y00 screwdriver to remove the four 6.3 mm-long screws securing the back panel.
  2. Nintendo Switch Lite Battery Disconnection, Remove the top and bottom back panel screws: passo 2, imagem 1 %32 Nintendo Switch Lite Battery Disconnection, Remove the top and bottom back panel screws: passo 2, imagem 2 %32
    • Use a JIS 000 driver or an official iFixit PH 000 driver to remove the following screws securing the back panel:
    • Two 3.6 mm-long screws on the top of the device
    • Two 3.6 mm-long screws on the bottom of the device
    • To prevent these tight screws from stripping, apply firm downward force, work slowly and try a different screwdriver if the screws won't come out.
  3. Nintendo Switch Lite Battery Disconnection, Release the clips securing the back panel: passo 3, imagem 1 %32 Nintendo Switch Lite Battery Disconnection, Release the clips securing the back panel: passo 3, imagem 2 %32
    • Insert an opening tool into the left speaker grille on the bottom of the device.
    • Twist the opening tool to release the clips securing the back panel.
    • Avoid inserting the opening tool further than required to prevent damage to the speaker module.
  4. Nintendo Switch Lite Battery Disconnection, Continue releasing the clips around the device: passo 4, imagem 1 %32 Nintendo Switch Lite Battery Disconnection, Continue releasing the clips around the device: passo 4, imagem 2 %32
    • Slide the opening tool around the bottom-left corner to release the clips on the left side of the device.
  5. Nintendo Switch Lite Battery Disconnection, Twist to release the clips: passo 5, imagem 1 %32 Nintendo Switch Lite Battery Disconnection, Twist to release the clips: passo 5, imagem 2 %32
    • Insert an opening tool into the right speaker grille on the bottom of the device.
    • Twist the opening tool to release the clips.
  6. Nintendo Switch Lite Battery Disconnection, Slide and pry around the corners: passo 6, imagem 1 %32 Nintendo Switch Lite Battery Disconnection, Slide and pry around the corners: passo 6, imagem 2 %32
    • Slide and pry the opening tool around the bottom-right corner to release the clips on the right side of the device.
  7. Nintendo Switch Lite Battery Disconnection: passo 7, imagem 1 %32 Nintendo Switch Lite Battery Disconnection: passo 7, imagem 2 %32
    • Continue sliding and prying the opening tool along the gap on the top of the device to release the clips.
  8. Nintendo Switch Lite Battery Disconnection, Remove the back panel: passo 8, imagem 1 %32 Nintendo Switch Lite Battery Disconnection, Remove the back panel: passo 8, imagem 2 %32 Nintendo Switch Lite Battery Disconnection, Remove the back panel: passo 8, imagem 3 %32
    • Lift the bottom edge of the back panel, opening it like a book.
    • Remove the back panel.
  9. Nintendo Switch Lite Battery Disconnection, Remove the shield plate: passo 9, imagem 1 %32
    • Use a JIS 000 driver or an official iFixit PH 000 driver to remove the following four screws:
    • Three 3.1 mm screws
    • One 4.5 mm screw
  10. Nintendo Switch Lite Battery Disconnection: passo 10, imagem 1 %32 Nintendo Switch Lite Battery Disconnection: passo 10, imagem 2 %32 Nintendo Switch Lite Battery Disconnection: passo 10, imagem 3 %32
    • Use a spudger or your fingers to lift the shield plate up and out of the device.
    • You may feel a bit of resistance. This is normal, since the shield plate is slightly bonded to the heat sink with thermal paste.
    • Remove the shield plate.
    • Clean off the old thermal paste from the shield plate and heat sink using isopropyl alcohol and a microfiber cloth. Apply new thermal paste to the heat sink before reassembly.
  11. Nintendo Switch Lite Battery Disconnection, Disconnect the battery: passo 11, imagem 1 %32 Nintendo Switch Lite Battery Disconnection, Disconnect the battery: passo 11, imagem 2 %32
    • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the motherboard interconnect cable's ZIF connector.
  12. Nintendo Switch Lite Battery Disconnection: passo 12, imagem 1 %32 Nintendo Switch Lite Battery Disconnection: passo 12, imagem 2 %32
    • Do Not Use Metal Tweezers! Some fixers state that metallic tweezers can short circuit the ribbon cable/connector. It might be safer to just use nylon-tipped or ceramic-tipped tweezers.
    • Use a pair of tweezers to slide the interconnect cable out of its connector on the motherboard.
  13. Nintendo Switch Lite Battery Disconnection: passo 13, imagem 1 %32 Nintendo Switch Lite Battery Disconnection: passo 13, imagem 2 %32
    • Use the point of a spudger to pry the battery connector straight up and out of its socket on the motherboard.
Conclusão
Uma outra pessoa concluiu este guia.
Craig Lloyd
Membro desde: 02/10/16
41.945 Reputação
Autoria de 82 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 36
Ao todo: 343
