Ir para o conteúdo principal
Nintendo Switch Lite Back Panel Replacement
O que você precisa
  1. Nintendo Switch Lite Back Panel Replacement, Remove the back panel screws: passo 1, imagem 1 %32
    Ferramenta utilizada neste passo:
    Magnetic Project Mat
    $19.95
    • Before beginning this repair, make sure that the device is completely turned off.
    • Use a Y00 screwdriver to remove the four 6.3 mm-long screws securing the back panel.
  2. Nintendo Switch Lite Back Panel Replacement, Remove the top and bottom back panel screws: passo 2, imagem 1 %32 Nintendo Switch Lite Back Panel Replacement, Remove the top and bottom back panel screws: passo 2, imagem 2 %32
    • Use a JIS 000 driver or an official iFixit PH 000 driver to remove the following screws securing the back panel:
    • Two 3.6 mm-long screws on the top of the device
    • Two 3.6 mm-long screws on the bottom of the device
    • To prevent these tight screws from stripping, apply firm downward force, work slowly and try a different screwdriver if the screws won't come out.
  3. Nintendo Switch Lite Back Panel Replacement, Release the clips securing the back panel: passo 3, imagem 1 %32 Nintendo Switch Lite Back Panel Replacement, Release the clips securing the back panel: passo 3, imagem 2 %32
    • Insert an opening tool into the left speaker grille on the bottom of the device.
    • Twist the opening tool to release the clips securing the back panel.
    • Avoid inserting the opening tool further than required to prevent damage to the speaker module.
  4. Nintendo Switch Lite Back Panel Replacement, Continue releasing the clips around the device: passo 4, imagem 1 %32 Nintendo Switch Lite Back Panel Replacement, Continue releasing the clips around the device: passo 4, imagem 2 %32
    • Slide the opening tool around the bottom-left corner to release the clips on the left side of the device.
  5. Nintendo Switch Lite Back Panel Replacement, Twist to release the clips: passo 5, imagem 1 %32 Nintendo Switch Lite Back Panel Replacement, Twist to release the clips: passo 5, imagem 2 %32
    • Insert an opening tool into the right speaker grille on the bottom of the device.
    • Twist the opening tool to release the clips.
  6. Nintendo Switch Lite Back Panel Replacement, Slide and pry around the corners: passo 6, imagem 1 %32 Nintendo Switch Lite Back Panel Replacement, Slide and pry around the corners: passo 6, imagem 2 %32
    • Slide and pry the opening tool around the bottom-right corner to release the clips on the right side of the device.
  7. Nintendo Switch Lite Back Panel Replacement: passo 7, imagem 1 %32 Nintendo Switch Lite Back Panel Replacement: passo 7, imagem 2 %32
    • Continue sliding and prying the opening tool along the gap on the top of the device to release the clips.
  8. Nintendo Switch Lite Back Panel Replacement, Remove the back panel: passo 8, imagem 1 %32 Nintendo Switch Lite Back Panel Replacement, Remove the back panel: passo 8, imagem 2 %32 Nintendo Switch Lite Back Panel Replacement, Remove the back panel: passo 8, imagem 3 %32
    • Lift the bottom edge of the back panel, opening it like a book.
    • Remove the back panel.
Conclusão
Compare your new replacement part to the original part. You may need to transfer remaining components or remove adhesive backings from the new part before installing.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Nintendo Switch Lite Answers community for help.
19 outras pessoas executaram este guia.
Craig Lloyd
Membro desde: 02/10/16
41.928 Reputação
Autoria de 82 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 12
Últimos 7 dias: 76
Últimos 30 dias: 528
Ao todo: 28,785
