Ir para o conteúdo principal
Nintendo NES Advantage Joystick Spring Replacement
O que você precisa
  1. Nintendo NES Advantage Joystick Spring Replacement, Back Panel: passo 1, imagem 1 %32
    • Remove the four sticky pads from the bottom of the device.
    • If the pads are stuck, use a spudger to remove them.
    Pergunte ao FixBot
    Comentar
  2. Nintendo NES Advantage Joystick Spring Replacement: passo 2, imagem 1 %32 Nintendo NES Advantage Joystick Spring Replacement: passo 2, imagem 2 %32
    • Remove the six 8 mm screws from the bottom of the device with a Phillips #0 screwdriver.
    • Use your hands to pull the back panel away from the controller.
    Pergunte ao FixBot
    Comentar
  3. Nintendo NES Advantage Joystick Spring Replacement, Joystick Panel: passo 3, imagem 1 %32
    • Remove the four 12 mm screws from the small square panel on the right with a Phillips #0 screwdriver.
    • While removing the last (fourth) screw, apply downward pressure on the panel. This will make it easier to remove the last screw because of the joystick spring on the other side of this panel.
    Pergunte ao FixBot
    Comentar
  4. Nintendo NES Advantage Joystick Spring Replacement: passo 4, imagem 1 %32 Nintendo NES Advantage Joystick Spring Replacement: passo 4, imagem 2 %32
    • Remove the small square panel.
    • This panel is connected with wires to the main circuit board. To replace the joystick panel, you will need to desolder the wires. To learn more about soldering, refer to our Como soldar e dessoldar contatos guide.
    Pergunte ao FixBot
    Comentar
  5. Nintendo NES Advantage Joystick Spring Replacement, Joystick: passo 5, imagem 1 %32 Nintendo NES Advantage Joystick Spring Replacement, Joystick: passo 5, imagem 2 %32
    • Using your hands, unscrew the ball on top of the joystick.
    Pergunte ao FixBot
    Comentar
  6. Nintendo NES Advantage Joystick Spring Replacement: passo 6, imagem 1 %32
    • Pull the joystick through the back of the NES Advantage Gamepad.
    Pergunte ao FixBot
    Comentar
  7. Nintendo NES Advantage Joystick Spring Replacement, Joystick Spring: passo 7, imagem 1 %32 Nintendo NES Advantage Joystick Spring Replacement, Joystick Spring: passo 7, imagem 2 %32 Nintendo NES Advantage Joystick Spring Replacement, Joystick Spring: passo 7, imagem 3 %32
    • Using your fingers, pull the spring up and off.
    Pergunte ao FixBot
    Comentar
Conclusão
Danielle Guthrie
Membro desde: 09/06/22
97 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 27
Ao todo: 589
