Ir para o conteúdo principal
Nintendo GameCube Fan replacement for cleaning
O que você precisa
  1. Nintendo GameCube Fan replacement for cleaning, Top Case: passo 1, imagem 1 %32 Nintendo GameCube Fan replacement for cleaning, Top Case: passo 1, imagem 2 %32 Nintendo GameCube Fan replacement for cleaning, Top Case: passo 1, imagem 3 %32
    • Turn over the Gamecube so that the bottom side is facing up.
    • Use the 4.5 mm Gamebit screwdriver to remove all four screws.
    Pergunte ao FixBot
    Comentar
  2. Nintendo GameCube Fan replacement for cleaning: passo 2, imagem 1 %32 Nintendo GameCube Fan replacement for cleaning: passo 2, imagem 2 %32 Nintendo GameCube Fan replacement for cleaning: passo 2, imagem 3 %32
    • With the bottom side of the GameCube facing upward and the screws removed, carefully pull the outer shell of the unit away from the top half.
    • Move the GameCube so that the inside is facing upwards.
    Pergunte ao FixBot
    Comentar
  3. Nintendo GameCube Fan replacement for cleaning, Fan: passo 3, imagem 1 %32 Nintendo GameCube Fan replacement for cleaning, Fan: passo 3, imagem 2 %32
    • Using a Phillips #2 screwdriver, remove the two screws (circled in red) attaching the fan assembly to the unit.
    • Carefully disconnect the fan connector from the socket, as depicted in the second picture.
    • The controller connector panel can be gently pulled out of the main unit and laid down, as depicted. This is not strictly required, but may provide more maneuverability inside the case.
    • Make sure to not pull out the wires while removing the fan. Doing so may damage the connector wire or the PCB.
    Pergunte ao FixBot
    Comentar
  4. Nintendo GameCube Fan replacement for cleaning: passo 4, imagem 1 %32 Nintendo GameCube Fan replacement for cleaning: passo 4, imagem 2 %32
    • Once the fan is removed, use compressed air to clean the dust off of the fan blades.
    • It is highly recommended that you use a toothpick to prevent the fan blades from moving while cleaning. This will prevent accidental damage to the fans motor.
    Pergunte ao FixBot
    Comentar
Conclusão
14 outras pessoas executaram este guia.
dcarlin
Membro desde: 11/05/09
399 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 6-2, Maness Fall 2009 Membro de Cal Poly, Team 6-2, Maness Fall 2009
CPSU-MANESS-F09S6G2
4 Membros
Autoria de 45 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 12
Últimos 7 dias: 38
Últimos 30 dias: 228
Ao todo: 42,617
