Ir para o conteúdo principal
Nintendo GameCube Controller Buttons Replacement
O que você precisa
  1. Nintendo GameCube Controller Buttons Replacement, Back Panel: passo 1, imagem 1 %32
    • Place the controller (buttons down) on a solid surface.
    • Remove the six 9.2mm Tri-wing Y0 screws that hold the back panel in place.
    Pergunte ao FixBot
    Comentar
  2. Nintendo GameCube Controller Buttons Replacement: passo 2, imagem 1 %32
    • Gently lift the back panel up, separating it from the front panel.
    • Some of the buttons may fall out if they are knocked around.
    Pergunte ao FixBot
    Comentar
  3. Nintendo GameCube Controller Buttons Replacement, Z Button: passo 3, imagem 1 %32 Nintendo GameCube Controller Buttons Replacement, Z Button: passo 3, imagem 2 %32
    • Grab the Z-button by the peg with tweezers and lift it out of the controller.
    • During re-assembly, make sure the plastic rim and spring fit into the slot provided, or else the case will not shut.
    Pergunte ao FixBot
    Comentar
  4. Nintendo GameCube Controller Buttons Replacement, Circuit Board: passo 4, imagem 1 %32
    • Carefully unhook the cable that is looped around the peg.
    Pergunte ao FixBot
    Comentar
  5. Nintendo GameCube Controller Buttons Replacement: passo 5, imagem 1 %32
    • Lift the circuit board out of the controller.
    • Do not grab the rumble motor to lift the circuit board as shown in the picture. It will in many cases just remove the rumble motor. Instead, grab the edges of the board.
    Pergunte ao FixBot
    Comentar
  6. Nintendo GameCube Controller Buttons Replacement, Buttons: passo 6, imagem 1 %32 Nintendo GameCube Controller Buttons Replacement, Buttons: passo 6, imagem 2 %32
    • Remove the rubber backing that covers the buttons.
    Pergunte ao FixBot
    Comentar
  7. Nintendo GameCube Controller Buttons Replacement: passo 7, imagem 1 %32 Nintendo GameCube Controller Buttons Replacement: passo 7, imagem 2 %32 Nintendo GameCube Controller Buttons Replacement: passo 7, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Use tweezers to lift buttons out of their sockets.
    • When putting the buttons back, make sure the slots properly fit back together.
    Pergunte ao FixBot
    Comentar
Conclusão
20 outras pessoas executaram este guia.
Sean Michel
Membro desde: 01/14/13
2.750 Reputação
Autoria de 8 guias
Equipe
Cal Poly, Team 19-44, Regan Winter 2013 Membro de Cal Poly, Team 19-44, Regan Winter 2013
CPSU-REGAN-W13S19G44
4 Membros
Autoria de 34 guias
3Comentários do guia
Is there a way I can buy the buttons separably? I lost a the X button and it's gone missing and i wanna buy one :(
tp4yourbunghole - Responder Compartilhar
u can either get a 2 dollar full button set on ebay by searching ngc buttons or u can buy from battle beaver customs for 1 dollar
dariuscorrfz - Responder Compartilhar
How do you put the back back on?
Steven Enns - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 34
Últimos 30 dias: 193
Ao todo: 32,985
