Ir para o conteúdo principal
Nintendo Game Boy Advance SP Power Switch Cover Replacement
O que você precisa
  1. Nintendo Game Boy Advance SP Power Switch Cover Replacement, Battery: passo 1, imagem 1 %32
    • Use a standard Phillips #00 screwdriver to loosen the 4 mm screw that keeps the battery cover attached to the device.
    Quel est le nom du vis svp je l'ai perdu et j'ai pas la référence
    la chaîne de Samarium - Responder
    Bonjour @lachainede96340 D'après les instructions du tutoriel, il s'agit d'une vis Phillips (ou cruciforme) #00 de 4 mm de long. Ces mesures devraient suffire pour trouver une vis de remplacement dans votre stock de vis ou en magasin le cas échéant.
    Claire Miesch -
  2. Nintendo Game Boy Advance SP Power Switch Cover Replacement: passo 2, imagem 1 %32
    • Lift the battery cover up and remove it from the device.
    • The screw will remain attached to the battery cover because of Nintendo's design.
  3. Nintendo Game Boy Advance SP Power Switch Cover Replacement: passo 3, imagem 1 %32
    • Use your fingers or a plastic opening tool to remove the battery from the device.
    • Caution: Please exercise caution when handling the battery. If it appears to be swelling or damaged at all it is considered a fire hazard.
  4. Nintendo Game Boy Advance SP Power Switch Cover Replacement, Back Cover: passo 4, imagem 1 %32 Nintendo Game Boy Advance SP Power Switch Cover Replacement, Back Cover: passo 4, imagem 2 %32
    • Remove four 6.5 mm screws from the corners of the back cover using a tri-point Y00 screwdriver.
    • Remove two 4.6mm screws from the top-center and bottom-center of the device using a tri-point Y00 screwdriver.
  5. Nintendo Game Boy Advance SP Power Switch Cover Replacement: passo 5, imagem 1 %32
    • Lift the back cover off of the device.
    • Potential for device damage: These inner components are vulnerable to static electricity. Exercise caution when handling these next steps to prevent damaging the device.
    • Look out for the power switch that can fall out when taking the back cover off.
  6. Nintendo Game Boy Advance SP Power Switch Cover Replacement, Power Switch Cover: passo 6, imagem 1 %32 Nintendo Game Boy Advance SP Power Switch Cover Replacement, Power Switch Cover: passo 6, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Lift the power switch cover away from the left side of the device using your fingers or tweezers.
Conclusão
17 outras pessoas executaram este guia.
DJ Pantone
Membro desde: 01/11/13
1.938 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 17-22, Forte Winter 2013 Membro de Cal Poly, Team 17-22, Forte Winter 2013
CPSU-FORTE-W13S17G22
4 Membros
Autoria de 41 guias
2 comentários
This doesn't explain anything about how to replace the switch
Michael - Responder
Maybe the guide was for replacing the power switch cover?
Dominick Scheible - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 29
Últimos 30 dias: 159
Ao todo: 21,525
