Ir para o conteúdo principal
Nintendo Game Boy Advance SP Battery Replacement
O que você precisa
  1. Nintendo Game Boy Advance SP Battery Replacement, Battery: passo 1, imagem 1 %32
    • Use a standard Phillips #00 screwdriver to loosen the 4 mm screw that keeps the battery cover attached to the device.
    Quel est le nom du vis svp je l'ai perdu et j'ai pas la référence
    la chaîne de Samarium - Responder
    Bonjour @lachainede96340 D'après les instructions du tutoriel, il s'agit d'une vis Phillips (ou cruciforme) #00 de 4 mm de long. Ces mesures devraient suffire pour trouver une vis de remplacement dans votre stock de vis ou en magasin le cas échéant.
    Claire Miesch -
  2. Nintendo Game Boy Advance SP Battery Replacement: passo 2, imagem 1 %32
    • Lift the battery cover up and remove it from the device.
    • The screw will remain attached to the battery cover because of Nintendo's design.
  3. Nintendo Game Boy Advance SP Battery Replacement: passo 3, imagem 1 %32
    • Use your fingers or a plastic opening tool to remove the battery from the device.
    • Caution: Please exercise caution when handling the battery. If it appears to be swelling or damaged at all it is considered a fire hazard.
Conclusão
For reassembly, follow the instructions in reverse order.
31 outras pessoas executaram este guia.
Rocco Lattanzio
Membro desde: 01/11/13
1.009 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 17-22, Forte Winter 2013 Membro de Cal Poly, Team 17-22, Forte Winter 2013
CPSU-FORTE-W13S17G22
4 Membros
Autoria de 41 guias
3Comentários do guia
This task is not very easy, its easy.
Very easy: Does not require opening device.
Easy: Requires minimal disassembly and requires a few tools like a Philips or flat-head screwdriver.
This however requires opening device.
Santi12008 - Responder
Why so pedantic?
keegan clow -
Thanks for yout guideline. I settle in 5 minutes.
aam9999 - Responder
Comentar
Visualizações:
Últimas 24 horas: 28
Últimos 7 dias: 130
Últimos 30 dias: 878
Ao todo: 74,667
