Introdução
The Ninja NJ600 blender has an LED light display to help the user operate it. This guide will show how to replace one of these lights.
O que você precisa
Remove the five screws (13mm long, 6mm head diameter) using a Phillips #2 screwdriver.
Remove these four screws (10mm long, 5mm head diameter) using a Phillips #2 screwdriver.
Locate the LED you wish to desolder.
On the bottom of the board, each LED is designated with a small triangle with a line at one tip.
