Ir para o conteúdo principal
Nikon D80 Flash Assembly Replacement
O que você precisa
    1. Nikon D80 Flash Assembly Replacement, Flash Assembly: passo 1, imagem 1 %32 Nikon D80 Flash Assembly Replacement, Flash Assembly: passo 1, imagem 2 %32 Nikon D80 Flash Assembly Replacement, Flash Assembly: passo 1, imagem 3 %32
      • Press the highlighted button to pop the flash up.
      • Otherwise, use a plastic opening tool to gently lever open the flash by inserting the tool into the gap between the flash and the camera.
      Pergunte ao FixBot
      Comentar
    2. Nikon D80 Flash Assembly Replacement: passo 2, imagem 1 %32
      • Use the #00 Phillips-head screwdriver to remove both 4.20 mm screws by rotating the screwdriver to the left.
      Pergunte ao FixBot
      Comentar
    3. Nikon D80 Flash Assembly Replacement: passo 3, imagem 1 %32 Nikon D80 Flash Assembly Replacement: passo 3, imagem 2 %32
      • Using a plastic opening tool, pry open the cover.
      • Be advised, some plastic struts may snap off when you remove the cover.
      Pergunte ao FixBot
      Comentar
    4. Nikon D80 Flash Assembly Replacement: passo 4, imagem 1 %32 Nikon D80 Flash Assembly Replacement: passo 4, imagem 2 %32
      • Using a soldering iron, desolder the orange, tan, and gray wires from the flash assembly.
      • For more information on how to solder and desolder connections, please visit this guide.
      • Use caution while using the hot soldering iron.
      Pergunte ao FixBot
      Comentar
    5. Nikon D80 Flash Assembly Replacement: passo 5, imagem 1 %32
      • Gently remove the flash assembly from the casing.
      • The surface may still be hot, so grab it with caution.
      Pergunte ao FixBot
      Comentar
Conclusão
Equipe
USF Tampa, Team S1-G1, Leahy Fall 2017 Membro de USF Tampa, Team S1-G1, Leahy Fall 2017
USFT-LEAHY-F17S1G1
4 Membros
Autoria de 17 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 14
Últimos 30 dias: 48
Ao todo: 2,953
