Ir para o conteúdo principal
Nikon Coolpix L840 Buttons Replacement
O que você precisa
    1. Nikon Coolpix L840 Buttons Replacement, Motherboard: passo 1, imagem 1 %32 Nikon Coolpix L840 Buttons Replacement, Motherboard: passo 1, imagem 2 %32 Nikon Coolpix L840 Buttons Replacement, Motherboard: passo 1, imagem 3 %32
      • Unscrew all eight black, 4mm screws with a Philips 000. (The top-most screw shown in the third image can be accessed by lifting the cover flap off.)
      Pergunte ao FixBot
      Comentar
    2. Nikon Coolpix L840 Buttons Replacement: passo 2, imagem 1 %32
      • Pry case open with a metal spludger by slipping the spludger between the back and front case of the camera and wiggling the spludger forwards and backwards.
      • Be careful not to damage the inner components of the camera when slipping the spludger into the camera.
      Pergunte ao FixBot
      Comentar
    3. Nikon Coolpix L840 Buttons Replacement: passo 3, imagem 1 %32 Nikon Coolpix L840 Buttons Replacement: passo 3, imagem 2 %32
      Ferramenta utilizada neste passo:
      • Carefully unhook the silver strip with tweezers. Get a grasp of the sides of the silver strip with the tweezers, and pull upwards and out.
      • The strip may also be identified by its blue tip, which becomes more visible once pulled out.
      Pergunte ao FixBot
      Comentar
    1. Nikon Coolpix L840 Buttons Replacement, Buttons: passo 4, imagem 1 %32
      • Unscrew the two, right-most, 2 mm screws with a Philips 000.
      • Unscrew the left-most, 4 mm screw with a Philips 000.
      Pergunte ao FixBot
      Comentar
    2. Nikon Coolpix L840 Buttons Replacement: passo 5, imagem 1 %32
      • Slide off the button panel in the marked direction.
      Pergunte ao FixBot
      Comentar
    3. Nikon Coolpix L840 Buttons Replacement: passo 6, imagem 1 %32
      • Flip to the front side of the button panel to access the button sensors.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
Cal Poly, Team 1-11, Maness Spring 2016 Membro de Cal Poly, Team 1-11, Maness Spring 2016
CPSU-MANESS-S16S1G11
4 Membros
Autoria de 10 guias
1Comentário do guia
Where can I get a replacement board for the buttons?
rush - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 7
Últimos 7 dias: 15
Últimos 30 dias: 50
Ao todo: 3,149
