Ir para o conteúdo principal
Nikon Coolpix L840 Motherboard Replacement
O que você precisa
  1. Nikon Coolpix L840 Motherboard Replacement, Motherboard: passo 1, imagem 1 %32 Nikon Coolpix L840 Motherboard Replacement, Motherboard: passo 1, imagem 2 %32 Nikon Coolpix L840 Motherboard Replacement, Motherboard: passo 1, imagem 3 %32
    • Unscrew all eight black, 4mm screws with a Philips 000. (The top-most screw shown in the third image can be accessed by lifting the cover flap off.)
  2. Nikon Coolpix L840 Motherboard Replacement: passo 2, imagem 1 %32
    • Pry case open with a metal spludger by slipping the spludger between the back and front case of the camera and wiggling the spludger forwards and backwards.
    • Be careful not to damage the inner components of the camera when slipping the spludger into the camera.
  3. Nikon Coolpix L840 Motherboard Replacement: passo 3, imagem 1 %32 Nikon Coolpix L840 Motherboard Replacement: passo 3, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Carefully unhook the silver strip with tweezers. Get a grasp of the sides of the silver strip with the tweezers, and pull upwards and out.
    • The strip may also be identified by its blue tip, which becomes more visible once pulled out.
Conclusão
3 outras pessoas executaram este guia.
Abraham Lozano
Membro desde: 04/11/16
598 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 1-11, Maness Spring 2016 Membro de Cal Poly, Team 1-11, Maness Spring 2016
CPSU-MANESS-S16S1G11
4 Membros
Autoria de 10 guias
2 comentários
I was trying to find how to replace the CCD lens sensor on the Nikon Coolpix L840
waynelguyton - Responder
My camera display will work for a bit, but then goes off. Subsequent efforts to start it yield poor results. If I pick it up and try again in a few hours, I may have a short time to work before the screen goes dark. The batteries are new. I think this might be a case of blown capacitors on board, but I could use insight. The motherboard costs more than the camera now.
Stephen Scanlan - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 17
Ao todo: 2,183
