Ir para o conteúdo principal
Nikon Coolpix L330 Image Sensor Replacement
O que você precisa
    1. Nikon Coolpix L330 Image Sensor Replacement, Back Housing: passo 1, imagem 1 %32 Nikon Coolpix L330 Image Sensor Replacement, Back Housing: passo 1, imagem 2 %32 Nikon Coolpix L330 Image Sensor Replacement, Back Housing: passo 1, imagem 3 %32
      • There are six screws attaching the back housing to the camera. Remove the screws from the body with a PH000 screw head.
      • Two 1.5x2.5mm screws on the right side.
      • Two 1.5x2.5mm screws on the underside.
      • Two 1.5x2.5mm screw on the left side.
      Pergunte ao FixBot
      Comentar
    2. Nikon Coolpix L330 Image Sensor Replacement: passo 2, imagem 1 %32 Nikon Coolpix L330 Image Sensor Replacement: passo 2, imagem 2 %32
      • After removing the screws, use a metal spudger or plastic opening tool to push the back cover out.
      • The metal spudger can damage the plastic housing, so use caution when applying any pressure to it. Use a plastic opening tool to reduce the risk of damage to the housing.
      • Remove the back housing of the camera by lifting it directly up.
      • The back cover may be slightly tight, therefore more force may be needed to lift it up.
      Pergunte ao FixBot
      Comentar
    1. Nikon Coolpix L330 Image Sensor Replacement, LCD Screen: passo 3, imagem 1 %32 Nikon Coolpix L330 Image Sensor Replacement, LCD Screen: passo 3, imagem 2 %32
      • Insert the tips of your fingers into the space between the screen and back-plate.
      • Gently lift the screen up and out of the frame.
      • The screen is still held by a flexible display cable, therefore only lift the screen 0.5'' out of the back-plate.
      Pergunte ao FixBot
      Comentar
    2. Nikon Coolpix L330 Image Sensor Replacement: passo 4, imagem 1 %32 Nikon Coolpix L330 Image Sensor Replacement: passo 4, imagem 2 %32
      • Tilt the screen so that the display cable forms a hinge with the backplate.
      • Rotate the display 180 degrees so that it faces you.
      Pergunte ao FixBot
      Comentar
    3. Nikon Coolpix L330 Image Sensor Replacement: passo 5, imagem 1 %32 Nikon Coolpix L330 Image Sensor Replacement: passo 5, imagem 2 %32 Nikon Coolpix L330 Image Sensor Replacement: passo 5, imagem 3 %32
      • The display cable has a ZIF (zero insertion force) connector on the end. This has a tab that has to be pushed out before the cable can be safely removed.
      • Using a plastic opening tool or fingernail, pop up the black clip holding the display cable. This will release the cable.
      • Slide the display cable out of the connector.
      • The display cable can be damaged due to excessive bending, therefore avoid putting unnecessary strain on it.
      Pergunte ao FixBot
      Comentar
    1. Nikon Coolpix L330 Image Sensor Replacement, Motherboard: passo 6, imagem 1 %32
      • Remove the screws from the silver back-plate with a PH000 screw head.
      • Two 1.5x2.5mm screws on the left side.
      • One 1.5x2.5mm screw on the right side.
      Pergunte ao FixBot
      Comentar
    2. Nikon Coolpix L330 Image Sensor Replacement: passo 7, imagem 1 %32
      • The marked red box contains a highly charged capacitor. Check the charge using a voltmeter and discharge it first before continuing. Discharge capacitor guide.
      • Remove the screws holding the motherboard with a PH000 screw head.
      Pergunte ao FixBot
      Comentar
    3. Nikon Coolpix L330 Image Sensor Replacement: passo 8, imagem 1 %32
      • Using a plastic opening tool or fingernail, pop up the black clips holding the ribbon cables. This will release the cables.
      • Slide the ribbon cables out of the connectors.
      Pergunte ao FixBot
      Comentar
    4. Nikon Coolpix L330 Image Sensor Replacement: passo 9, imagem 1 %32 Nikon Coolpix L330 Image Sensor Replacement: passo 9, imagem 2 %32 Nikon Coolpix L330 Image Sensor Replacement: passo 9, imagem 3 %32
      • Remove the black sticker covering the electrical connections.
      • Desolder the eight wires from the motherboard.
      Pergunte ao FixBot
      Comentar
    5. Nikon Coolpix L330 Image Sensor Replacement: passo 10, imagem 1 %32 Nikon Coolpix L330 Image Sensor Replacement: passo 10, imagem 2 %32 Nikon Coolpix L330 Image Sensor Replacement: passo 10, imagem 3 %32
      • Insert a plastic opening tool into the marked position. Push the tool towards the right to release the clip.
      • Using a thumb and forefinger, push the plastic cover up until it is at a 45 degree angle.
      • Pull the cover back and up to release it.
      Pergunte ao FixBot
      Comentar
    6. Nikon Coolpix L330 Image Sensor Replacement: passo 11, imagem 1 %32 Nikon Coolpix L330 Image Sensor Replacement: passo 11, imagem 2 %32
      • The motherboard is still held in place by soldered connections.
      • Carefully desolder the connections .
      • The front cover has been removed in this picture, however the procedure is still the same.
      Pergunte ao FixBot
      Comentar
    7. Nikon Coolpix L330 Image Sensor Replacement: passo 12, imagem 1 %32
      • Remove the motherboard by lifting it directly up.
      Pergunte ao FixBot
      Comentar
    1. Nikon Coolpix L330 Image Sensor Replacement, Image Sensor: passo 13, imagem 1 %32 Nikon Coolpix L330 Image Sensor Replacement, Image Sensor: passo 13, imagem 2 %32
      • Remove the three 1.5x2.5mm screws using a PH000 screw head.
      Pergunte ao FixBot
      Comentar
    2. Nikon Coolpix L330 Image Sensor Replacement: passo 14, imagem 1 %32 Nikon Coolpix L330 Image Sensor Replacement: passo 14, imagem 2 %32
      • Remove the three 1.5x1.75mm screws holding the lens in place using a PH000 screw head.
      • Lift the image sensor up and out of the bracket.
      Pergunte ao FixBot
      Comentar
Conclusão
Rajeev
Membro desde: 02/09/16
623 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 2-10, Cagle Spring 2016 Membro de USF Tampa, Team 2-10, Cagle Spring 2016
USFT-CAGLE-S16S2G10
4 Membros
Autoria de 14 guias
1Comentário do guia
In Step 11, there is one board right? I need that board. May I know where to purchase that board?
CJ Ramki - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 11
Últimos 30 dias: 33
Ao todo: 1,259
