Ir para o conteúdo principal
Nike SportWatch GPS Unit Replacement
O que você precisa
    1. Nike SportWatch GPS Unit Replacement, GPS Unit: passo 1, imagem 1 %32
      • Using a size #000 Phillips screwdriver, remove the six 5 mm screws on the back of the device.
      Pergunte ao FixBot
      Comentar
    2. Nike SportWatch GPS Unit Replacement: passo 2, imagem 1 %32
      • Then, gently pull the watch band and front screen apart.
      Pergunte ao FixBot
      Comentar
    3. Nike SportWatch GPS Unit Replacement: passo 3, imagem 1 %32
      • Using a size #000 Phillips screwdriver, remove the two 2.5 mm screws on the main board.
      Pergunte ao FixBot
      Comentar
    4. Nike SportWatch GPS Unit Replacement: passo 4, imagem 1 %32
      • Carefully, use the blue plastic opening tool to pry the main board out of the front panel.
      • Use extreme care when handling the ribbon cable. Avoid twisting or pulling it, as it is delicate and cannot be removed or replaced if damaged.
      Pergunte ao FixBot
      Comentar
    5. Nike SportWatch GPS Unit Replacement: passo 5, imagem 1 %32
      • Using the spudger, remove the orange tape that covers the wire for the GPS.
      Pergunte ao FixBot
      Comentar
    6. Nike SportWatch GPS Unit Replacement: passo 6, imagem 1 %32
      • Using the soldering iron, break the wire connecting the GPS to the main board at the connector.
      • When desoldering the GPS wire, set the soldering iron to a moderate heat level (around 350°C/662°F). To prevent damage, avoid prolonged contact with the board. For detailed instructions, refer to the iFixit soldering guide.
      Pergunte ao FixBot
      Comentar
    7. Nike SportWatch GPS Unit Replacement: passo 7, imagem 1 %32
      • To reassemble, follow the steps in reverse order. Ensure all connections are secure, screws are tightened evenly, and no ribbon cables are pinched. Once complete, test the watch by powering it on and verifying GPS functionality in an open area.
      Pergunte ao FixBot
      Comentar
    8. Nike SportWatch GPS Unit Replacement: passo 8, imagem 1 %32
      • After reassembly, power on the watch and perform a GPS test outdoors in a clear area. Wait for the watch to acquire a signal to confirm the successful replacement.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Ian Eichorn
Membro desde: 10/22/15
696 Reputação
Autoria de 4 guias
Equipe
UMass Dartmouth, Team 5-8, Gulbrandsen Fall 2015 Membro de UMass Dartmouth, Team 5-8, Gulbrandsen Fall 2015
UMASSD-GULBRANDSEN-F15S5G8
3 Membros
Autoria de 5 guias
3Comentários do guia
which GPS unit is it?
charles - Responder Compartilhar
what gps unit is it?
I would also like to know what GPS unit that is and if it is possible to find a replacement or a compatible unit?
avs4820 - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 36
Ao todo: 2,329
