Ir para o conteúdo principal
Nextbook Premium 7SE Battery Replacement
O que você precisa
  1. Nextbook Premium 7SE Battery Replacement, Back Cover: passo 1, imagem 1 %32 Nextbook Premium 7SE Battery Replacement, Back Cover: passo 1, imagem 2 %32 Nextbook Premium 7SE Battery Replacement, Back Cover: passo 1, imagem 3 %32
    • Insert the plastic opening tool into the middle of the bottom edge of the device. The tool should be inserted within the seam between the back and front covers.
    • Slide the opening tool to the right and slowly continue to separate the back cover from the device.
    • Avoid prying on the buttons, as they are easily damaged.
    Pergunte ao FixBot
    Comentar
  2. Nextbook Premium 7SE Battery Replacement: passo 2, imagem 1 %32
    • Pull the cover off of the device once about three quarters of the cover has been pried open using the plastic opening tool.
    Pergunte ao FixBot
    Comentar
  3. Nextbook Premium 7SE Battery Replacement, Battery: passo 3, imagem 1 %32
    • Remove masking tape from the battery.
    Pergunte ao FixBot
    Comentar
  4. Nextbook Premium 7SE Battery Replacement: passo 4, imagem 1 %32 Nextbook Premium 7SE Battery Replacement: passo 4, imagem 2 %32 Nextbook Premium 7SE Battery Replacement: passo 4, imagem 3 %32
    • Pry the battery from the base using the nylon spudger and move it away from the motherboard.
    • Handle the battery with care to avoid damaging it.
    Pergunte ao FixBot
    Comentar
  5. Nextbook Premium 7SE Battery Replacement: passo 5, imagem 1 %32 Nextbook Premium 7SE Battery Replacement: passo 5, imagem 2 %32 Nextbook Premium 7SE Battery Replacement: passo 5, imagem 3 %32
    • De-solder the three contact points and remove the battery.
    • See the following guide for instructions on how to solder. Como soldar e dessoldar contatos
    • Use caution when operating the soldering iron.
    Pergunte ao FixBot
    Comentar
Conclusão
To reassemble your device, follow these instructions in reverse order, being careful when re-soldering the contacts back into place.
Uma outra pessoa concluiu este guia.
Equipe
Baylor, Team 4-1, Williams Fall 2016 Membro de Baylor, Team 4-1, Williams Fall 2016
BU-WILLIAMS-F16S4G1
4 Membros
Autoria de 14 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 17
Ao todo: 1,012
