Ir para o conteúdo principal
NeuTab N7 Pro Speaker Replacement
O que você precisa
  1. NeuTab N7 Pro Speaker Replacement, Speaker: passo 1, imagem 1 %32
    • Power off your device before beginning disassembly.
    • Insert plastic opening tool and pry back case away from the device, slowly moving the plastic opening tool along the device.
    Pergunte ao FixBot
    Comentar
  2. NeuTab N7 Pro Speaker Replacement: passo 2, imagem 1 %32 NeuTab N7 Pro Speaker Replacement: passo 2, imagem 2 %32
    • The speaker is attached to the back cover of the device.
    • Hold positive and negative wires as close as possible to the speaker. Use small plastic spudger and fingers to simultaneously lift speaker from cover.
    Pergunte ao FixBot
    Comentar
  3. NeuTab N7 Pro Speaker Replacement: passo 3, imagem 1 %32 NeuTab N7 Pro Speaker Replacement: passo 3, imagem 2 %32 NeuTab N7 Pro Speaker Replacement: passo 3, imagem 3 %32
    • Use a soldering gun to remove the positive and negative wires connecting the battery to the circuit board.
    • For a complete guide on how to solder, click here.
    • Be sure not to touch both the positive and negative terminal at the same time.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Travis McLean
Membro desde: 02/09/16
322 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 7-1, Cheng Spring 2016 Membro de USF Tampa, Team 7-1, Cheng Spring 2016
USFT-CHENG-S16S7G1
3 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 18
Ao todo: 509
