Ir para o conteúdo principal
NeuTab Air7 Battery Replacement
O que você precisa
    1. NeuTab Air7 Battery Replacement, Back Cover: passo 1, imagem 1 %32 NeuTab Air7 Battery Replacement, Back Cover: passo 1, imagem 2 %32 NeuTab Air7 Battery Replacement, Back Cover: passo 1, imagem 3 %32
      • Ensure your device is powered off before you begin.
      • Use the opening tool to gently pry the back cover off of the tablet, running it along the perimeter of the device.
      Pergunte ao FixBot
      Comentar
    1. NeuTab Air7 Battery Replacement, Battery: passo 2, imagem 1 %32 NeuTab Air7 Battery Replacement, Battery: passo 2, imagem 2 %32
      • The following instructions require soldering, which can risk burn injuries as well as component damage for those novice in the skill. Tread with caution.
      • For a guide on how to solder, click here.
      • Remove any adhesive tape that is holding the wires protruding from the battery down.
      • De-solder the red and black wire ends that connect the battery to the motherboard.
      Pergunte ao FixBot
      Comentar
    2. NeuTab Air7 Battery Replacement: passo 3, imagem 1 %32 NeuTab Air7 Battery Replacement: passo 3, imagem 2 %32
      • Using metal tools can cause damage to the battery and potentially create a fire hazard. ESD safe tools are recommended for this operation.
      • Wedge a plastic or nylon spudger underneath the battery, moving it back and forth to separate it from the device.
      • Remove the battery.
      Pergunte ao FixBot
      Comentar
Conclusão
Jason Soares
Membro desde: 10/29/23
532 Reputação
Autoria de 5 guias
Equipe
UMass Dartmouth, Team 2-1, Gulbrandsen Fall 2023 Membro de UMass Dartmouth, Team 2-1, Gulbrandsen Fall 2023
UMASSD-GULBRANDSEN-F23S2G1
4 Membros
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 26
Ao todo: 435
