Ir para o conteúdo principal
Netgear WGR614v9 Capacitor Replacement
O que você precisa
    1. Netgear WGR614v9 Capacitor Replacement, Lower Case: passo 1, imagem 1 %32
      • Rotate the device so that the bottom is facing up.
      Pergunte ao FixBot
      Comentar
    2. Netgear WGR614v9 Capacitor Replacement: passo 2, imagem 1 %32 Netgear WGR614v9 Capacitor Replacement: passo 2, imagem 2 %32
      • Lift up all four rubber pads on the bottom of the router with the plastic opening tool.
      • Be careful not to pull the rubber pads all the way out when lifting as they are difficult to reinsert.
      Pergunte ao FixBot
      Comentar
    3. Netgear WGR614v9 Capacitor Replacement: passo 3, imagem 1 %32 Netgear WGR614v9 Capacitor Replacement: passo 3, imagem 2 %32
      • Unscrew the four 11.8 mm T-8 torx screws from the bottom of the router.
      Pergunte ao FixBot
      Comentar
    4. Netgear WGR614v9 Capacitor Replacement: passo 4, imagem 1 %32
      • Lift the bottom casing straight up from the router.
      Pergunte ao FixBot
      Comentar
    1. Netgear WGR614v9 Capacitor Replacement, Motherboard: passo 5, imagem 1 %32
      • Remove the clear plastic casing by lifting it straight up from the router.
      Pergunte ao FixBot
      Comentar
    2. Netgear WGR614v9 Capacitor Replacement: passo 6, imagem 1 %32 Netgear WGR614v9 Capacitor Replacement: passo 6, imagem 2 %32
      • Separate the motherboard from the top shell by lifting it straight up from the router.
      Pergunte ao FixBot
      Comentar
    1. Netgear WGR614v9 Capacitor Replacement, Capacitor: passo 7, imagem 1 %32 Netgear WGR614v9 Capacitor Replacement, Capacitor: passo 7, imagem 2 %32
      • Rotate the motherboard so that the top is facing up.
      • Set the motherboard on a flat clean surface.
      Pergunte ao FixBot
      Comentar
    2. Netgear WGR614v9 Capacitor Replacement: passo 8, imagem 1 %32 Netgear WGR614v9 Capacitor Replacement: passo 8, imagem 2 %32
      • The capacitor can be found at the location shown.
      Pergunte ao FixBot
      Comentar
    3. Netgear WGR614v9 Capacitor Replacement: passo 9, imagem 1 %32 Netgear WGR614v9 Capacitor Replacement: passo 9, imagem 2 %32
      • Rotate the motherboard so that the bottom is facing up.
      • Locate the two soldered contacts of the capacitor.
      Pergunte ao FixBot
      Comentar
    4. Netgear WGR614v9 Capacitor Replacement: passo 10, imagem 1 %32 Netgear WGR614v9 Capacitor Replacement: passo 10, imagem 2 %32 Netgear WGR614v9 Capacitor Replacement: passo 10, imagem 3 %32
      • Rotate the motherboard 180 degrees.
      • Do not refer to the pictures in this step for proper de-soldering and soldering techniques. They are for illustration purposes only.
      • Refer to this link for proper de-soldering and soldering techniques.
      • Pull the capacitor from the other side of the circuit board once the solder is liquified.
      • To replace the capacitor, orient the negative side of the capacitor (indicated by a white stripe and a negative sign) so that it aligns with the shaded white region of the circle indicating the capacitor's position on the motherboard.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Kyle Moore
Membro desde: 10/03/11
95 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 21-24, Maness Fall 2011 Membro de Cal Poly, Team 21-24, Maness Fall 2011
CPSU-MANESS-F11S21G24
4 Membros
Autoria de 32 guias
1Comentário do guia
looks like that's a 220microF at 25V right ?
probably better to replace it with a similar 220microF, but with higher voltage rating.
email_etran - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 17
Últimos 30 dias: 52
Ao todo: 3,821
