Ir para o conteúdo principal
Netgear WGR614v9 Antenna Replacement
O que você precisa
    1. Netgear WGR614v9 Antenna Replacement, Lower Case: passo 1, imagem 1 %32
      • Rotate the device so that the bottom is facing up.
      Pergunte ao FixBot
      Comentar
    2. Netgear WGR614v9 Antenna Replacement: passo 2, imagem 1 %32 Netgear WGR614v9 Antenna Replacement: passo 2, imagem 2 %32
      • Lift up all four rubber pads on the bottom of the router with the plastic opening tool.
      • Be careful not to pull the rubber pads all the way out when lifting as they are difficult to reinsert.
      Pergunte ao FixBot
      Comentar
    3. Netgear WGR614v9 Antenna Replacement: passo 3, imagem 1 %32 Netgear WGR614v9 Antenna Replacement: passo 3, imagem 2 %32
      • Unscrew the four 11.8 mm T-8 torx screws from the bottom of the router.
      Pergunte ao FixBot
      Comentar
    4. Netgear WGR614v9 Antenna Replacement: passo 4, imagem 1 %32
      • Lift the bottom casing straight up from the router.
      Pergunte ao FixBot
      Comentar
    1. Netgear WGR614v9 Antenna Replacement, Motherboard: passo 5, imagem 1 %32
      • Remove the clear plastic casing by lifting it straight up from the router.
      Pergunte ao FixBot
      Comentar
    2. Netgear WGR614v9 Antenna Replacement: passo 6, imagem 1 %32 Netgear WGR614v9 Antenna Replacement: passo 6, imagem 2 %32
      • Separate the motherboard from the top shell by lifting it straight up from the router.
      Pergunte ao FixBot
      Comentar
    1. Netgear WGR614v9 Antenna Replacement, Antenna: passo 7, imagem 1 %32 Netgear WGR614v9 Antenna Replacement, Antenna: passo 7, imagem 2 %32
      • Rotate the motherboard so that the top is facing up.
      • Set the motherboard on a flat clean surface.
      Pergunte ao FixBot
      Comentar
    2. Netgear WGR614v9 Antenna Replacement: passo 8, imagem 1 %32 Netgear WGR614v9 Antenna Replacement: passo 8, imagem 2 %32
      • Do not refer to the pictures in this step for proper de-soldering and soldering techniques. They are for illustration purposes only.
      • Refer to this link for proper de-soldering and soldering techniques.
      • Be patient. This may take some time depending on the quality of your soldering iron.
      Pergunte ao FixBot
      Comentar
    3. Netgear WGR614v9 Antenna Replacement: passo 9, imagem 1 %32
      • Peel off the yellow tape holding the wires.
      • Set the tape aside on a clean surface so that it can be reused.
      Pergunte ao FixBot
      Comentar
    4. Netgear WGR614v9 Antenna Replacement: passo 10, imagem 1 %32 Netgear WGR614v9 Antenna Replacement: passo 10, imagem 2 %32
      • Extend the antenna outwards from the device so that it is straight.
      • Locate the clips that hold the antenna onto the router.
      • Push the clips in with one hand and pull the antenna out with your other hand. Slightly twist the antenna until it becomes free from the hole.
      Pergunte ao FixBot
      Comentar
    5. Netgear WGR614v9 Antenna Replacement: passo 11, imagem 1 %32
      • Pull out the antenna as well as the connected wire.
      Pergunte ao FixBot
      Comentar
Conclusão
3 outras pessoas executaram este guia.
Ryan Murphy
Membro desde: 10/03/11
488 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 21-24, Maness Fall 2011 Membro de Cal Poly, Team 21-24, Maness Fall 2011
CPSU-MANESS-F11S21G24
4 Membros
Autoria de 32 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 14
Últimos 30 dias: 42
Ao todo: 8,284
