Ir para o conteúdo principal
Nest Hello Button Replacement
O que você precisa
  1. Nest Hello Button Replacement, Casing and Faceplate: passo 1, imagem 1 %32
    • Insert the pick between the black faceplate and white casing of the Nest Hello.
    • Pry the faceplate away from the device with the opening pick.
    • If you have not opened the Nest Hello before, there will be a protective foam mesh that is glued to the plastic covering and the inside of the mesh, use a pick to cut through the mesh as much as possible.
    • Completely remove the faceplate from the device, do not be afraid to pull hard.
    Pergunte ao FixBot
    Comentar
  2. Nest Hello Button Replacement: passo 2, imagem 1 %32 Nest Hello Button Replacement: passo 2, imagem 2 %32
    • Peel back the cover stickers and use the Phillips #000 screwdriver to remove the four screws.
    Pergunte ao FixBot
    Comentar
  3. Nest Hello Button Replacement: passo 3, imagem 1 %32 Nest Hello Button Replacement: passo 3, imagem 2 %32 Nest Hello Button Replacement: passo 3, imagem 3 %32
    • Insert opening pick between the white casing and the black internal circuitry and pry it out.
    • There is a ribbon cable connecting the white casing to the circuit boards. Be careful not to tear out the cable while separating the casing from the circuit boards.
    Pergunte ao FixBot
    Comentar
  4. Nest Hello Button Replacement, Motherboard: passo 4, imagem 1 %32
    • Use the Phillips #000 to remove the two screws holding the ribbon cable to the white casing.
    Pergunte ao FixBot
    Comentar
  5. Nest Hello Button Replacement: passo 5, imagem 1 %32 Nest Hello Button Replacement: passo 5, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Grip the connector with the tweezers as shown and pull it away from the casing.
    Pergunte ao FixBot
    Comentar
  6. Nest Hello Button Replacement: passo 6, imagem 1 %32
    • Remove the six smaller screws shown with the Phillips #000 screwdriver.
    • Remove the three larger screws shown with the Phillips #000 screwdriver.
    Pergunte ao FixBot
    Comentar
  7. Nest Hello Button Replacement: passo 7, imagem 1 %32 Nest Hello Button Replacement: passo 7, imagem 2 %32
    • Holding the device as shown push the circuit board away from you and up to free it from the clips.
    Pergunte ao FixBot
    Comentar
  8. Nest Hello Button Replacement: passo 8, imagem 1 %32 Nest Hello Button Replacement: passo 8, imagem 2 %32
    • Use the Phillips #000 screwdriver to remove the three screws holding the last circuit board to the black plastic housing.
    Pergunte ao FixBot
    Comentar
  9. Nest Hello Button Replacement: passo 9, imagem 1 %32
    • Insert the pick underneath the black connectors and pry them upward to disconnect them from the circuit board.
    • Work your way around the device, prying the circuit board away from the housing.
    • Make sure to feed the wires when taking off the circuit board.
    Pergunte ao FixBot
    Comentar
    • Once the circuitboard is free from the plastic housing, the button can be removed by pushing on it from the front side.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
2Comentários do guia
Where do you get the parts. Google is no help. I’m trying to get the black faceplate from your first step. I can’t find it.
Ryan Gauder - Responder Compartilhar
Where do I buy a button?
Joel Lundi - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 16
Últimos 30 dias: 67
Ao todo: 4,162
