Ir para o conteúdo principal
Nest Hello O-Ring Replacement
O que você precisa
  1. Nest Hello O-Ring Replacement, Casing and Faceplate: passo 1, imagem 1 %32
    • Insert the pick between the black faceplate and white casing of the Nest Hello.
    • Pry the faceplate away from the device with the opening pick.
    • If you have not opened the Nest Hello before, there will be a protective foam mesh that is glued to the plastic covering and the inside of the mesh, use a pick to cut through the mesh as much as possible.
    • Completely remove the faceplate from the device, do not be afraid to pull hard.
    Pergunte ao FixBot
    Comentar
  2. Nest Hello O-Ring Replacement: passo 2, imagem 1 %32 Nest Hello O-Ring Replacement: passo 2, imagem 2 %32
    • Peel back the cover stickers and use the Phillips #000 screwdriver to remove the four screws.
    Pergunte ao FixBot
    Comentar
  3. Nest Hello O-Ring Replacement: passo 3, imagem 1 %32 Nest Hello O-Ring Replacement: passo 3, imagem 2 %32 Nest Hello O-Ring Replacement: passo 3, imagem 3 %32
    • Insert opening pick between the white casing and the black internal circuitry and pry it out.
    • There is a ribbon cable connecting the white casing to the circuit boards. Be careful not to tear out the cable while separating the casing from the circuit boards.
    Pergunte ao FixBot
    Comentar
  4. Nest Hello O-Ring Replacement, O-Ring: passo 4, imagem 1 %32
    • Remove the O-Ring (colored blue) from the device. It is placed around the edge of the motherboard.
    Pergunte ao FixBot
    Comentar
Conclusão
3 outras pessoas executaram este guia.
2Comentários do guia
Is there a link available for spare replacement parts? I can’t seem to find anything other than replacement internal batteries . Thanks!
Andres Chavez - Responder Compartilhar
Also looking for this replacement part. Googling did not produce results.
KB_KB - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 12
Últimos 30 dias: 76
Ao todo: 5,246
