Ir para o conteúdo principal
Nest Cam Wi-Fi Cable Replacement
O que você precisa
  1. Nest Cam Wi-Fi Cable Replacement, Wi-Fi Cable: passo 1, imagem 1 %32
    • Remove the four 6 mm screws from the back panel with the J000 Phillips head screwdriver.
    • We suggest designated areas to keep track of all screws.
  2. Nest Cam Wi-Fi Cable Replacement: passo 2, imagem 1 %32 Nest Cam Wi-Fi Cable Replacement: passo 2, imagem 2 %32 Nest Cam Wi-Fi Cable Replacement: passo 2, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Open the back panel completely to expose the inside of the Nest Cam.
    • Using the tweezers, disconnect the red and black mic cable from the motherboard.
  3. Nest Cam Wi-Fi Cable Replacement: passo 3, imagem 1 %32 Nest Cam Wi-Fi Cable Replacement: passo 3, imagem 2 %32 Nest Cam Wi-Fi Cable Replacement: passo 3, imagem 3 %32
    • Disconnect the black Wi-Fi cable from the top of the motherboard with tweezers.
    • Use a plastic spudger to lift the motherboard and camera up enough to expose and disconnect the white cable with the tweezers.
    • Remove motherboard and camera completely from the housing.
    The connector on one of mine is messed up. Where do you find the cables that need replacing?
    Mike Novack - Responder
  4. Nest Cam Wi-Fi Cable Replacement: passo 4, imagem 1 %32
    • Using a soldering iron, melt away the base of the Wi-Fi cable until it can be removed. Use this guild for assistance with soldering.
    • Ensure when you solder the new cable back on that all connector ends are positioned correctly.
Conclusão
Uma outra pessoa concluiu este guia.
Jade Weiss
Membro desde: 02/24/16
662 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 1-1, Leahy Spring 2016 Membro de USF Tampa, Team 1-1, Leahy Spring 2016
USFT-LEAHY-S16S1G1
7 Membros
Autoria de 10 guias
2Comentários do guia
I have broken the cable attached to Nest camera. Can you get replacement or repair the lead? Hope i haven't got to buy a new camera
Kerrie Davies - Responder
I have broken lead attached to Nest camera. Can i get a replacement or repair it? Hope i havent got to buy a new camera.
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 20
Ao todo: 4,537
