Ir para o conteúdo principal
Motorola Moto G5 Battery Replacement
O que você precisa
  1. Motorola Moto G5 Battery Replacement, Back Cover: passo 1, imagem 1 %32 Motorola Moto G5 Battery Replacement, Back Cover: passo 1, imagem 2 %32
    • Insert your fingernail or the flat end of a spudger into the notch on the bottom edge of the phone near the charging port.
    • Pry with your fingernail or twist the spudger to release the back cover from the phone.
  2. Motorola Moto G5 Battery Replacement: passo 2, imagem 1 %32 Motorola Moto G5 Battery Replacement: passo 2, imagem 2 %32 Motorola Moto G5 Battery Replacement: passo 2, imagem 3 %32
    • Insert the flat end of a spudger into the seam and slide it along the bottom edge to release the clips holding the back cover to the phone.
  3. Motorola Moto G5 Battery Replacement: passo 3, imagem 1 %32 Motorola Moto G5 Battery Replacement: passo 3, imagem 2 %32 Motorola Moto G5 Battery Replacement: passo 3, imagem 3 %32
    • Continue sliding the flat end of the spudger along the seam for the remaining sides of the phone.
  4. Motorola Moto G5 Battery Replacement: passo 4, imagem 1 %32 Motorola Moto G5 Battery Replacement: passo 4, imagem 2 %32
    • Lift the back cover and remove it from the phone.
    • To reinstall the back cover, align the cover with the phone and squeeze along the edges to snap the clips back into place.
  5. Motorola Moto G5 Battery Replacement, Battery: passo 5, imagem 1 %32 Motorola Moto G5 Battery Replacement, Battery: passo 5, imagem 2 %32
    • Insert your fingernail or the flat end of the spudger into the notch below the battery.
    • Pry with your fingernail or spudger until you free the battery from its recess.
  6. Motorola Moto G5 Battery Replacement: passo 6, imagem 1 %32
    • Remove the battery.
    • When installing the battery, make sure the battery's contacts line up with the three gold pins on the top right.
Conclusão
After completing this guide, calibrate your newly-installed battery.
Repair didn’t go as planned? Check out our Motorola Moto G5 Answers community for troubleshooting help.
9 outras pessoas executaram este guia.
Arthur Shi
Membro desde: 01/03/18
252.842 Reputação
Autoria de 526 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 135
Autoria de 16.817 guias
5 comentários
this is not the g5 replacement procedure. it will not work.need to remove screen.
Tom Tercek - Responder
@Tom Tercek - You are in a huge mistake. This is the Motorola Moto G5 phone and the battery is removable and as shown on the pics, very easy to replace.
prishylets - Responder
is it also possible with moto g5s?
Jojo Blublub - Responder
Unfortunately, the G5S does not have an easily replaceable battery.
Arthur Shi -
Hi, I'm looking for parts for Moto G5, specifically an intern plastic cover that goes over the charge port.
Leonardo - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 18
Últimos 7 dias: 84
Últimos 30 dias: 448
Duração total: 39,178
