Ir para o conteúdo principal
Motorola Moto G 5G (2022) Motherboard Removal
Pré-requisito somente
Este guia destina-se apenas a ser usado como pré-requisito para outros guias. É incompleto por si só.
O que você precisa
  1. Motorola Moto G 5G (2022) Motherboard Removal, Eject the SIM card tray: passo 1, imagem 1 %32 Motorola Moto G 5G (2022) Motherboard Removal, Eject the SIM card tray: passo 1, imagem 2 %32
    • Insert a SIM card eject tool or a straightened paperclip into the hole adjacent to the SIM card tray.
    • Press firmly to eject the tray.
  2. Motorola Moto G 5G (2022) Motherboard Removal, Remove the SIM card tray: passo 2, imagem 1 %32
    • Remove the SIM card tray from the phone.
    • When reinserting the SIM card, make sure it's in the proper orientation inside the tray.
  3. Motorola Moto G 5G (2022) Motherboard Removal, Back cover removal information: passo 3, imagem 1 %32 Motorola Moto G 5G (2022) Motherboard Removal, Back cover removal information: passo 3, imagem 2 %32
    • Discharge your battery to 25% or less and completely power off your phone before you begin.
    • Take note of the following seams along the edge of the phone:
    • Screen seam: This seam separates the display panel from the frame. Don't pry at this seam.
    • Bezel seam: This is where the plastic back cover meets the rest of the phone. It's held in place by plastic clips. This is where you should pry.
  4. Motorola Moto G 5G (2022) Motherboard Removal, Insert an opening pick: passo 4, imagem 1 %32 Motorola Moto G 5G (2022) Motherboard Removal, Insert an opening pick: passo 4, imagem 2 %32 Motorola Moto G 5G (2022) Motherboard Removal, Insert an opening pick: passo 4, imagem 3 %32
    • Insert an opening tool in the bezel seam halfway between the bottom-right corner of the phone and the power button.
    • Insert an opening pick in the gap you just created.
  5. Motorola Moto G 5G (2022) Motherboard Removal, Release the right clips: passo 5, imagem 1 %32 Motorola Moto G 5G (2022) Motherboard Removal, Release the right clips: passo 5, imagem 2 %32
    • Slide your opening pick toward the bottom-right corner of the back cover and release the clips.
    • As each clip releases, you will hear and feel a pop.
    • Don't slide the opening pick near the power or volume buttons.
  6. Motorola Moto G 5G (2022) Motherboard Removal, Release the bottom clips: passo 6, imagem 1 %32 Motorola Moto G 5G (2022) Motherboard Removal, Release the bottom clips: passo 6, imagem 2 %32
    • Continue sliding your opening pick towards the bottom left corner to unclip the bottom edge of the back cover.
  7. Motorola Moto G 5G (2022) Motherboard Removal, Release the left clips: passo 7, imagem 1 %32 Motorola Moto G 5G (2022) Motherboard Removal, Release the left clips: passo 7, imagem 2 %32 Motorola Moto G 5G (2022) Motherboard Removal, Release the left clips: passo 7, imagem 3 %32
    • Slide your opening pick toward the top left corner to unclip the left side of the back cover.
  8. Motorola Moto G 5G (2022) Motherboard Removal, Release the top clips: passo 8, imagem 1 %32 Motorola Moto G 5G (2022) Motherboard Removal, Release the top clips: passo 8, imagem 2 %32
    • Slide your pick around the top left corner and along the top edge to release the clips.
  9. Motorola Moto G 5G (2022) Motherboard Removal: passo 9, imagem 1 %32 Motorola Moto G 5G (2022) Motherboard Removal: passo 9, imagem 2 %32
    • Slide your pick around the top right corner to release the last clips securing the back cover.
    • Stop before reaching the volume buttons. Your pick may damage their cables.
  10. Motorola Moto G 5G (2022) Motherboard Removal, Remove the back cover: passo 10, imagem 1 %32 Motorola Moto G 5G (2022) Motherboard Removal, Remove the back cover: passo 10, imagem 2 %32 Motorola Moto G 5G (2022) Motherboard Removal, Remove the back cover: passo 10, imagem 3 %32
    • Don't try to remove the back cover all the way yet, as it's still connected to the frame by the power button cable.
    • With SIM card slot facing you, swing the back cover open and away from you like you're opening a book.
    • Rest the cover parallel to the frame.
    • Don't twist the screen or move it too far away from the frame to avoid damaging the power button cable.
  11. Motorola Moto G 5G (2022) Motherboard Removal, Remove the power button: passo 11, imagem 1 %32 Motorola Moto G 5G (2022) Motherboard Removal, Remove the power button: passo 11, imagem 2 %32
    Ferramenta utilizada neste passo:
    • A small rubber arm connects the power button to its recess. Use caution to avoid tearing this piece.
    • Use tweezers or your fingers to unhook the power button's rubber arm from its recess and remove it.
  12. Motorola Moto G 5G (2022) Motherboard Removal, Only the back cover remains: passo 12, imagem 1 %32
    • You're now left with the back cover.
    • This is a good point to test your phone before sealing it up. Follow this guide to perform a hardware test. Be sure to power your phone back down completely before you continue working.
  13. Motorola Moto G 5G (2022) Motherboard Removal, Unfasten the power button cable bracket: passo 13, imagem 1 %32 Motorola Moto G 5G (2022) Motherboard Removal, Unfasten the power button cable bracket: passo 13, imagem 2 %32
    • Use a PH00 screwdriver to remove the two 3.9 mm-long screws securing the power button cable bracket.
  14. Motorola Moto G 5G (2022) Motherboard Removal, Remove the power button cable bracket: passo 14, imagem 1 %32 Motorola Moto G 5G (2022) Motherboard Removal, Remove the power button cable bracket: passo 14, imagem 2 %32
    • Use your fingers or a pair of blunt nose tweezers to grab and remove the bracket from the power button cable.
  15. Motorola Moto G 5G (2022) Motherboard Removal, Disconnect the power button: passo 15, imagem 1 %32 Motorola Moto G 5G (2022) Motherboard Removal, Disconnect the power button: passo 15, imagem 2 %32
    • Use the pointed end of a spudger to pry up and disconnect the power button's press connector.
  16. Motorola Moto G 5G (2022) Motherboard Removal, Remove the power button: passo 16, imagem 1 %32 Motorola Moto G 5G (2022) Motherboard Removal, Remove the power button: passo 16, imagem 2 %32
    • Grab and remove the power button.
    • If you're using tweezers, take care not to puncture the battery—a punctured battery may leak dangerous chemicals or cause a fire.
  17. Motorola Moto G 5G (2022) Motherboard Removal, Unfasten the motherboard cover: passo 17, imagem 1 %32 Motorola Moto G 5G (2022) Motherboard Removal, Unfasten the motherboard cover: passo 17, imagem 2 %32
    • Use your Phillips screwdriver to remove the eight 3.9 mm-long screws securing the motherboard cover.
  18. Motorola Moto G 5G (2022) Motherboard Removal, Pry the motherboard cover: passo 18, imagem 1 %32 Motorola Moto G 5G (2022) Motherboard Removal, Pry the motherboard cover: passo 18, imagem 2 %32
    • Insert an opening pick between the bottom-left corner of the cover and the motherboard.
    • Pry up to release the cover's small clips securing it to the frame.
    • Don't pry against the battery. Use protrusions in the frame for leverage.
    • Work your way around the perimeter to free the cover if it feels stuck.
  19. Motorola Moto G 5G (2022) Motherboard Removal, Remove the motherboard cover: passo 19, imagem 1 %32 Motorola Moto G 5G (2022) Motherboard Removal, Remove the motherboard cover: passo 19, imagem 2 %32 Motorola Moto G 5G (2022) Motherboard Removal, Remove the motherboard cover: passo 19, imagem 3 %32
    • Grab and remove the motherboard cover from the phone.
  20. Motorola Moto G 5G (2022) Motherboard Removal, Disconnect the battery: passo 20, imagem 1 %32 Motorola Moto G 5G (2022) Motherboard Removal, Disconnect the battery: passo 20, imagem 2 %32
    • Use the pointed end of a spudger to pry and disconnect the battery's press connector.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  21. Motorola Moto G 5G (2022) Motherboard Removal, Peel away the tape: passo 21, imagem 1 %32 Motorola Moto G 5G (2022) Motherboard Removal, Peel away the tape: passo 21, imagem 2 %32 Motorola Moto G 5G (2022) Motherboard Removal, Peel away the tape: passo 21, imagem 3 %32
    • Peel the tape from the display connector.
    • If you are using a pair of tweezers, use caution to avoid the battery.
    • If you're having trouble peeling the tape, heat an iOpener and apply it to the tape for 60 seconds.
  22. Motorola Moto G 5G (2022) Motherboard Removal, Disconnect the display: passo 22, imagem 1 %32 Motorola Moto G 5G (2022) Motherboard Removal, Disconnect the display: passo 22, imagem 2 %32
    • Use the pointed end of a spudger to pry and disconnect the screen's press connector.
  23. Motorola Moto G 5G (2022) Motherboard Removal, Lift the graphite film: passo 23, imagem 1 %32 Motorola Moto G 5G (2022) Motherboard Removal, Lift the graphite film: passo 23, imagem 2 %32 Motorola Moto G 5G (2022) Motherboard Removal, Lift the graphite film: passo 23, imagem 3 %32
    • Fold the graphite heat film away from the battery to expose the lower section of the motherboard.
  24. Motorola Moto G 5G (2022) Motherboard Removal, Disconnect the board connector: passo 24, imagem 1 %32 Motorola Moto G 5G (2022) Motherboard Removal, Disconnect the board connector: passo 24, imagem 2 %32
    • Use the pointed end of a spudger to pry and disconnect the board cable's press connector.
  25. Motorola Moto G 5G (2022) Motherboard Removal, Disconnect the black antenna cable: passo 25, imagem 1 %32 Motorola Moto G 5G (2022) Motherboard Removal, Disconnect the black antenna cable: passo 25, imagem 2 %32 Motorola Moto G 5G (2022) Motherboard Removal, Disconnect the black antenna cable: passo 25, imagem 3 %32
    • Use the pointed end of your spudger to pry and disconnect the head of the black antenna cable.
    • Pry on only the metal head of the connector. Avoid lifting the cable itself as much as possible.
    • Free the cable from the clip below the head of the connector.
    • During reassembly, these can be tricky to reconnect. Hold the connector in place over its socket and press down with the flat end of a spudger. The connector should snap into place.
    • During reassembly, make sure to secure the cable to the clip below the head of the connector.
  26. Motorola Moto G 5G (2022) Motherboard Removal, Disconnect the white antenna cable: passo 26, imagem 1 %32 Motorola Moto G 5G (2022) Motherboard Removal, Disconnect the white antenna cable: passo 26, imagem 2 %32
    • Repeat the previous step for the white antenna cable.
  27. Motorola Moto G 5G (2022) Motherboard Removal, Unfasten the motherboard: passo 27, imagem 1 %32 Motorola Moto G 5G (2022) Motherboard Removal, Unfasten the motherboard: passo 27, imagem 2 %32
    • Use your Phillips screwdriver to remove the 2.9 mm-long screw from the bottom-right corner of the motherboard.
  28. Motorola Moto G 5G (2022) Motherboard Removal, Lift the motherboard: passo 28, imagem 1 %32 Motorola Moto G 5G (2022) Motherboard Removal, Lift the motherboard: passo 28, imagem 2 %32 Motorola Moto G 5G (2022) Motherboard Removal, Lift the motherboard: passo 28, imagem 3 %32
    • Insert the pointed end of a spudger between the lower left of the motherboard and the frame.
    • Lift upward on this bottom edge to free the motherboard from the frame.
  29. Motorola Moto G 5G (2022) Motherboard Removal, Remove the motherboard: passo 29, imagem 1 %32 Motorola Moto G 5G (2022) Motherboard Removal, Remove the motherboard: passo 29, imagem 2 %32
    • Grab the motherboard from the bottom edge and lift it from its recess.
    • Be sure the loose cables don't catch on the motherboard as its removed.
Conclusão
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
Clay Eickemeyer
Membro desde: 09/19/22
81.040 Reputação
Autoria de 455 guias
Equipe
Guide Team Membro de Guide Team
Staff
Membros da 9
Autoria de 11.338 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 55
