Introdução
This guide will show you how to replace the main camera of your Motorola Moto G 3rd Generation. Replacing this part requires disassembling much of the phone.
Ferramentas
Peças
Nenhum componente especificado.
Use your fingernail to pry under the notch on the bottom of the phone and remove the back cover.
Use a plastic opening tool to flip up the lock on the display cable ZIF connector.
Pull the display cable from its socket on the motherboard.
Remove the ten 2.4 mm T4 screws from the sides of the motherboard.
Remove the four 4.5 mm T4 screws from the top and bottom of the motherboard.
Remove the three 2.4 mm T4 screws from the right side and bottom of the SIM/SD card panel.
Pry off the main camera from its base using a plastic opening tool.
3 outras pessoas concluíram este guia.
