Ir para o conteúdo principal
Motorola Moto G 3rd Generation Display Replacement
O que você precisa
Vídeo de Apresentação
  1. Motorola Moto G 3rd Generation Display Replacement, Display: passo 1, imagem 1 %32 Motorola Moto G 3rd Generation Display Replacement, Display: passo 1, imagem 2 %32
    • Use your fingernail to pry under the notch on the bottom of the phone and remove the back cover.
    • Make sure to fully power off the phone before you begin disassembly.
    Pergunte ao FixBot
    Comentar
  2. Motorola Moto G 3rd Generation Display Replacement: passo 2, imagem 1 %32 Motorola Moto G 3rd Generation Display Replacement: passo 2, imagem 2 %32
    • Use a heat gun or an iOpener as a heating tool. This guide explains how to use the iOpener.
    • Evenly apply heat to the edges of the touchscreen to loosen the adhesive. Continue to Step 3 once the edge of the screen is warm to the touch.
    • Do not let the iOpener/heat gun remain on one spot for too long. Excess heat can damage the phone.
    • When reassembling the phone, use the iOpener/heat gun to help the adhesive fuse to the new screen. Heat the screen edges, apply pressure to the screen, and hold the screen in place until it is secure.
    Pergunte ao FixBot
    Comentar
  3. Motorola Moto G 3rd Generation Display Replacement: passo 3, imagem 1 %32 Motorola Moto G 3rd Generation Display Replacement: passo 3, imagem 2 %32 Motorola Moto G 3rd Generation Display Replacement: passo 3, imagem 3 %32
    • As the adhesive loosens, pry up an edge of the screen with a plastic opening tool or an opening pick. A suction cup may also be useful here.
    • Use an opening pick to hold that edge in place and continue this process around the entire screen, applying more heat as necessary.
    • Avoid damaging the LCD screen connector while prying along the screen edges. It is located on the left edge of the phone, across from the volume controls.
    • During reassembly, new adhesive may need to be applied over the old adhesive to properly secure the screen.
    Pergunte ao FixBot
    Comentar
  4. Motorola Moto G 3rd Generation Display Replacement: passo 4, imagem 1 %32 Motorola Moto G 3rd Generation Display Replacement: passo 4, imagem 2 %32 Motorola Moto G 3rd Generation Display Replacement: passo 4, imagem 3 %32
    Ferramenta utilizada neste passo:
    Tesa 61395 Tape
    $8.95
    • Use a plastic opening tool to flip up the lock on the display cable ZIF connector.
    • Pull the display cable from its socket on the motherboard.
    • When installing a new display, carefully remove all remaining adhesive from the phone, and clean the adhered areas with isopropyl alcohol (90% or greater) and a lint-free cloth. Install the display using pre-cut adhesive or a strong double-sided tape such as Tesa 61395. Turn your phone on and test your repair before sealing the display in place.
    Pergunte ao FixBot
    Comentar
Conclusão
52 outras pessoas executaram este guia.
Equipe
USF Tampa, Team 1-3, Nance Spring 2016 Membro de USF Tampa, Team 1-3, Nance Spring 2016
USFT-NANCE-S16S1G3
4 Membros
Autoria de 27 guias
20Comentários do guia
If your original screen has any adhesive tape on it's back (near to where the flat cable connects to the board), remove it from the original and put on the replacement piece, i've spent a lot of hours trying to undestand why my replacement screen worked fine out of the phone, but had some problems after puting it on the phone. After a lot of time i noticed this tape and did what i said, and the problem stoped, aparently is some kind short circuit betwen board and the screen aluminum back. Sorry bad english.
Leonardo Assef - Responder Compartilhar
Could you explain where the addhesive was a little bit more? I have my screen falling off from that corner and I've tried adding more addhesive but still... Wondering if the replacement is faulty.. I don't have the original anymore
rpalesh - Responder Compartilhar
Thank you soooooo much! I just had the same problem! many thanks for posting und best wishes. You are a great human being!
Felix Eikenberg - Responder Compartilhar
I had the same problem, now i ordered better adhesive. where is this tape? Do you have a picture?
sebastianwolz - Responder Compartilhar
In my case it was a yellow stripe unter the ZIF connector that prevents the socket from connecting with the back of the screen.
Julian Zimmermann - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 13
Últimos 30 dias: 73
Ao todo: 58,701
