Introdução
Follow this guide to replace the screen for the Motorola Moto E5 Play.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
For your safety, discharge your existing battery below 25% before disassembling your phone. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair.
O que você precisa
Insert your fingernail or the flat end of a spudger into the notch on the bottom right corner of the phone.
Pry with your fingernail or twist the spudger to release the back cover's clips from the phone.
Insert your fingernail or the flat end of the spudger into the notch at the bottom of the battery.
Pry with your fingernail or spudger to free the battery from its recess.
Remove the thirteen 3.5 mm-long T5 Torx screws securing the motherboard and daughterboard covers to the phone's frame.
Use the point of a spudger to pry up a corner of the black battery mat.
Use your fingers to slowly peel the battery mat from the frame.
It is not clear that the flex cable under the battery mat can easily tear near the end that is in the middle of the phone. There is a little tab at 90 degrees to the cable that is stuck to the back of the mat, but the rest of the cable is stuck to the phone body, and since it is not in any of the photos, you won’t know it’s there until it is torn. It’s unclear if you peel the mat all the way off, or just partially peel it back.
Hi Roger,
Thanks for the feedback! I’ll adjust the step instructions to incorporate your notes.
Repair didn’t go as planned? Check out our Motorola Moto E5 Play Answers community for troubleshooting help.
15 outras pessoas executaram este guia.
6 comentários
How do i get the screen out of the frame?
It’s all one component! I suppose it’s possible to separate them, but the part we sell includes the screen and the frame in one piece.
Yup, screen and frame comes as one piece. Just completed!
Do I need any adhesive to put it on the new frame? If so, what type and where does it go? Thanks!
No adhesive required!
