Ir para o conteúdo principal
Motorola Moto E5 Play Battery Replacement
O que você precisa
  1. Motorola Moto E5 Play Battery Replacement, Back Cover: passo 1, imagem 1 %32 Motorola Moto E5 Play Battery Replacement, Back Cover: passo 1, imagem 2 %32
    • Insert your fingernail or the flat end of a spudger into the notch on the bottom right corner of the phone.
    • Pry with your fingernail or twist the spudger to release the back cover's clips from the phone.
  2. Motorola Moto E5 Play Battery Replacement: passo 2, imagem 1 %32 Motorola Moto E5 Play Battery Replacement: passo 2, imagem 2 %32
    • Insert your fingernail or the flat end of a spudger into the seam on the bottom of the phone and slide it along the edge to release the clips holding the back cover to the phone.
  3. Motorola Moto E5 Play Battery Replacement: passo 3, imagem 1 %32 Motorola Moto E5 Play Battery Replacement: passo 3, imagem 2 %32
    • Continue sliding your fingernail or spudger along the seam around the rest of the phone to release the remaining clips.
  4. Motorola Moto E5 Play Battery Replacement: passo 4, imagem 1 %32 Motorola Moto E5 Play Battery Replacement: passo 4, imagem 2 %32
    • Lift the back cover and remove it from the phone.
    • To reinstall the back cover, align the cover with the phone and squeeze along the edges to snap the clips back into place.
  5. Motorola Moto E5 Play Battery Replacement, Battery: passo 5, imagem 1 %32 Motorola Moto E5 Play Battery Replacement, Battery: passo 5, imagem 2 %32
    • Insert your fingernail or the flat end of the spudger into the notch at the bottom of the battery.
    • Pry with your fingernail or spudger to free the battery from its recess.
  6. Motorola Moto E5 Play Battery Replacement: passo 6, imagem 1 %32
    • Remove the battery.
    • When installing the battery, make sure the battery's contacts line up with the three gold pins in the top right of the battery compartment.
Conclusão
Take the time to calibrate your new battery to ensure optimal functionality.
Repair didn’t go as planned? Check out our Motorola Moto E5 Play Answers community for troubleshooting help.
Craig Lloyd
Membro desde: 02/10/16
35.418 Reputação
Autoria de 82 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 21
Últimos 30 dias: 104
Duração total: 6,862
