Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
This is a very basic guide for removing the back cover—either to replace it for cosmetic reasons, or to gain access to internal components for servicing.
O que você precisa
Insert a fingernail or a spudger into the notch on the bottom edge of the phone, near the charge port.
Gently twist or pry to open a small gap between the back cover and the body of the phone.
While keeping your tool (or fingernail) inserted into the gap between the back cover and the body of the phone, slide it around the corner to begin loosening the plastic clips holding the cover in place.
