Ir para o conteúdo principal
Microsoft Surface Pro Battery Replacement
O que você precisa
  1. Microsoft Surface Pro Battery Replacement, Heat edges of display: passo 1, imagem 1 %32
    • Use a heated iOpener or a heat gun to heat the edges of the display and soften its adhesive.
    • If you're using an iOpener it may take several cycles of reheating and applying it to soften the adhesive enough. Every time, let the iOpener sit on the display for at least a minute before reheating to allow the adhesive to soften.
    Pergunte ao FixBot
    Comentar
  2. Microsoft Surface Pro Battery Replacement, Lift display and cut adhesive: passo 2, imagem 1 %32 Microsoft Surface Pro Battery Replacement, Lift display and cut adhesive: passo 2, imagem 2 %32 Microsoft Surface Pro Battery Replacement, Lift display and cut adhesive: passo 2, imagem 3 %32
    • Apply a suction cup as close as possible to the edge of the display.
    • Use the suction cup to lift the edge of the display enough to insert an opening pick under the edge.
    • Slide the opening pick all the way around the edges of the display to cut through the adhesive on the bezel.
    • Do not insert the opening pick past the bezel of the display—you may permanently damage the display.
    • The bezel is much thinner on the bottom of the display, which is the side with the Windows logo. To avoid damage, don't poke too deep with the opening pick on the bottom edge.
    • Ribbon cables and a circuit board are approx. 0.6 cm from the edge of the glass.
    • Be very careful and move slowly during this step. The display is fragile and will crack if too much force is applied against it. If your tools seem stuck, apply more heat to further soften the adhesive.
    Pergunte ao FixBot
    Comentar
  3. Microsoft Surface Pro Battery Replacement, Disconnect/peel off ribbon cables: passo 3, imagem 1 %32 Microsoft Surface Pro Battery Replacement, Disconnect/peel off ribbon cables: passo 3, imagem 2 %32 Microsoft Surface Pro Battery Replacement, Disconnect/peel off ribbon cables: passo 3, imagem 3 %32
    • Starting from the top edge, lift the display slightly.
    • If you feel any resistance, use heat and an opening pick to slice through any remaining adhesive.
    • Before completely removing the display:
    • Disconnect the three display cables.
    • Gently peel from the frame 2 orange ribbon cables that are glued to it, as those should stay with the display. (e.g. use a thin plastic card to separate them)
    Pergunte ao FixBot
    Comentar
  4. Microsoft Surface Pro Battery Replacement, Removal: passo 4, imagem 1 %32
    • Remove the display.
    Pergunte ao FixBot
    Comentar
  5. Microsoft Surface Pro Battery Replacement, Battery: passo 5, imagem 1 %32 Microsoft Surface Pro Battery Replacement, Battery: passo 5, imagem 2 %32
    • Using a T3 Torx screwdriver, remove a total of 23 screws from the screen bezel of the Surface Pro.
    Pergunte ao FixBot
    Comentar
  6. Microsoft Surface Pro Battery Replacement: passo 6, imagem 1 %32
    • Lift the screen bezel from the Surface Pro.
    Pergunte ao FixBot
    Comentar
  7. Microsoft Surface Pro Battery Replacement: passo 7, imagem 1 %32 Microsoft Surface Pro Battery Replacement: passo 7, imagem 2 %32
    • Remove the 6 T5 screws from the panels on each side of the frame.
    • Remove 23 T2 screws from the panels.
    Pergunte ao FixBot
    Comentar
  8. Microsoft Surface Pro Battery Replacement: passo 8, imagem 1 %32
    • Lift both metal panels from the frame.
    Pergunte ao FixBot
    Comentar
  9. Microsoft Surface Pro Battery Replacement: passo 9, imagem 1 %32 Microsoft Surface Pro Battery Replacement: passo 9, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Using tweezers, gently pull the eight orange ribbon cables from their sockets.
    Pergunte ao FixBot
    Comentar
  10. Microsoft Surface Pro Battery Replacement: passo 10, imagem 1 %32 Microsoft Surface Pro Battery Replacement: passo 10, imagem 2 %32
    • Unscrew the 17 T5 torx screws on the mother board with the T5 torx screw driver
    Pergunte ao FixBot
    Comentar
  11. Microsoft Surface Pro Battery Replacement: passo 11, imagem 1 %32
    • Once all screws are removed, gently lift up the logic board with your hands to pull it out.
    Pergunte ao FixBot
    Comentar
  12. Microsoft Surface Pro Battery Replacement: passo 12, imagem 1 %32 Microsoft Surface Pro Battery Replacement: passo 12, imagem 2 %32
    • Use your hands to pry off the entire battery pack with enough force to overcome the glue keeping the batteries in place.
    Pergunte ao FixBot
    Comentar
Conclusão
40 outras pessoas executaram este guia.
Jonathan Choi
Membro desde: 10/09/13
1.090 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 8-20, Regan Fall 2013 Membro de Cal Poly, Team 8-20, Regan Fall 2013
CPSU-REGAN-F13S8G20
4 Membros
Autoria de 16 guias
24Comentários do guia
Thank you for that awesome guide!
Do you know where can i buy a battery for surface pro 2??
Thanks
John john - Responder Compartilhar
I am also trying to find out where to acquire the Surface Pro batteries...???
Tristan Irons - Responder Compartilhar
im also looking for a surface pro replacement battery.
Lekan Adesanya - Responder Compartilhar
I just bought one for $70 at a site called newpower99.com... should be here in 2 days. I have no idea if it will work, but it says it comes with a toolkit to replace it. I hope it works.
Matt - Responder Compartilhar
Did you have success installing the Newegg battery?
asmac - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 54
Últimos 7 dias: 227
Últimos 30 dias: 782
Ao todo: 270,329
