Ir para o conteúdo principal
Microsoft Surface Pro 5 Screen Replacement
O que você precisa
  1. Cuidado: os passos de 1 a 22 são provenientes de um guia marcado como em andamento.
    Microsoft Surface Pro 5 Screen Replacement, Heat the screen: passo 1, imagem 1 %32
    • Completely power off the Surface before you begin disassembly.
    • If the screen's glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping over the glass. Lay overlapping strips of clear packing tape over the display until all the glass is covered. Wear safety glasses to protect your eyes.
    • Heat an iOpener and apply it to the right edge of the Surface's screen for two minutes.
    • You may need to reheat and reapply the iOpener several times to get the Surface warm enough. Follow the iOpener instructions to avoid overheating.
    • A hair dryer, heat gun, or hot plate may also be used for more heat, but be careful not to overheat the Surface—the screen and internal battery are susceptible to heat damage.
    You may want to discharge the battery completely as I found it quite easy to accidentally bump the power button and turn the surface on while cutting through the screen adhesive.
    Emma Strainis - Responder
    I used my Mrs heat pad (a small electric blanket thing) just lay the tablet face down and fold the excess blanket over the back, in an hour its toasty .I also cleverly tore off the antenna which came off with the screen but found replacement at Aliexpress
    david granger - Responder
  2. Microsoft Surface Pro 5 Screen Replacement, Take note of the adhesive layout: passo 2, imagem 1 %32 Microsoft Surface Pro 5 Screen Replacement, Take note of the adhesive layout: passo 2, imagem 2 %32
    • Take note of the screen adhesive layout before continuing:
    • These areas only contain adhesive and are safe to cut.
    • The display board and flex cables sit here close to the edge. Cut very carefully and do not insert the pick as deep under the display.
    • Fragile antenna cables lie under this part of the screen. Carefully follow the procedure to avoid damaging them. The adhesive is also the thickest here.
    Be careful at the bottom of the screen also. If you put the picks in too far, you can severe the screen ribbon cables which happened to me. I successfully removed the screen without breaking it but severed those cables.
    Randall Takahashi - Responder
    Which is top?
    Mr B - Responder
  3. Microsoft Surface Pro 5 Screen Replacement, Insert an opening pick into the speaker opening: passo 3, imagem 1 %32 Microsoft Surface Pro 5 Screen Replacement, Insert an opening pick into the speaker opening: passo 3, imagem 2 %32
    • Insert an opening pick into the speaker opening on the screen and slide the pick under the glass. Do not press the pick into the speaker grille, as the grille is easily torn.
    • Don't insert the opening pick any deeper than the black bezel on the side of the screen. Inserting the pick too far may damage the LCD.
  4. Microsoft Surface Pro 5 Screen Replacement, Slide an opening pick under the screen: passo 4, imagem 1 %32 Microsoft Surface Pro 5 Screen Replacement, Slide an opening pick under the screen: passo 4, imagem 2 %32
    • Rotate the pick toward the bottom of the Surface to slide it underneath the lower edge of the speaker cutout.
  5. Microsoft Surface Pro 5 Screen Replacement, Cut through the screen adhesive: passo 5, imagem 1 %32 Microsoft Surface Pro 5 Screen Replacement, Cut through the screen adhesive: passo 5, imagem 2 %32
    • Slide the pick down the right edge of the Surface to slice through the adhesive under the screen.
    • Throughout the rest of the procedure, if you encounter significant resistance while sliding the pick, stop and reheat the section you're working on. Applying too much pressure with the pick can crack the glass.
    • Leave this opening pick in the right edge to prevent the adhesive from resealing.
  6. Microsoft Surface Pro 5 Screen Replacement: passo 6, imagem 1 %32
    • Reheat the iOpener and apply it to the bottom edge of the Surface's screen for two minutes.
  7. Microsoft Surface Pro 5 Screen Replacement: passo 7, imagem 1 %32 Microsoft Surface Pro 5 Screen Replacement: passo 7, imagem 2 %32 Microsoft Surface Pro 5 Screen Replacement: passo 7, imagem 3 %32
    • Insert a new opening pick into the bottom right corner and slide it around the corner toward the bottom edge.
    • Slide the pick along the bottom edge of the Surface to cut through the screen adhesive.
    • Leave this pick in the bottom edge to prevent the adhesive from resealing.
    Avoid pressing the pick more than 5mm into the lower edge. Driving the pick in as far as the edge of the bezel on the lower edge will damage ribbon cables.
    Bill Mills - Responder
    Bill is right! DO NOT GO IN MORE THAN 5mm, or 1/4 of an inch! Instructions should be corrected, including the top diagram! Be extremely careful on the bottom side, just as the top!
    Bill - Responder
  8. Microsoft Surface Pro 5 Screen Replacement: passo 8, imagem 1 %32
    • Reheat the iOpener and apply it to the left edge of the Surface's screen for two minutes.
  9. Microsoft Surface Pro 5 Screen Replacement: passo 9, imagem 1 %32 Microsoft Surface Pro 5 Screen Replacement: passo 9, imagem 2 %32 Microsoft Surface Pro 5 Screen Replacement: passo 9, imagem 3 %32
    • Insert a new opening pick into the bottom left corner and slide it around the corner toward the left edge.
    • Take care cutting under the lower 2.5 inches (65 mm) of the left edge. Do not insert the opening pick more than 1/8 inches (3 mm) here. The display cables sit near this part of the bezel and are easily damaged. Once past the display cable area, do not insert the pick past the bezel.
    • Slide the pick along the left edge of the Surface to cut through the screen adhesive.
    • Leave this pick in the left edge to prevent the adhesive from resealing.
  10. Microsoft Surface Pro 5 Screen Replacement: passo 10, imagem 1 %32
    • Reheat the iOpener and apply it to the top edge of the Surface's screen for two minutes.
    • The adhesive is thickest along this edge, and you may need to reheat and reapply the iOpener several times to get the Surface warm enough. Follow the iOpener instructions to avoid overheating.
  11. Microsoft Surface Pro 5 Screen Replacement: passo 11, imagem 1 %32 Microsoft Surface Pro 5 Screen Replacement: passo 11, imagem 2 %32 Microsoft Surface Pro 5 Screen Replacement: passo 11, imagem 3 %32
    • Round the left corner with the opening pick and slide it along the top edge of the Surface. Stop when the pick is 2.75 inches (70 mm) away from the left edge.
    • The next 6 inches (15 cm) of the top edge of the case is covered by the left and right antennas, which sit between the case and the screen bezel. Follow the next steps carefully to avoid damaging the antennas.
  12. Microsoft Surface Pro 5 Screen Replacement: passo 12, imagem 1 %32 Microsoft Surface Pro 5 Screen Replacement: passo 12, imagem 2 %32 Microsoft Surface Pro 5 Screen Replacement: passo 12, imagem 3 %32
    • Insert the point of a pick under the display where you just stopped cutting. Do not insert the pick deeper than the edge of the bezel.
    • Carefully roll the pick to the right, pressing the long edge of the pick into the screen adhesive underneath the bezel, cutting the adhesive as you go. Do not slide the pick along the edge of the Surface.
    • Keep the pick parallel to the screen throughout the whole procedure so that it doesn't catch on the antennas. Do not press the pick against the case.
    • Repeat this motion of inserting the point of the pick where you just cut, and rolling to the right all along the top edge of the Surface, until the pick is 2.5 inches (64 mm) from the right edge of the Surface.
  13. Microsoft Surface Pro 5 Screen Replacement: passo 13, imagem 1 %32 Microsoft Surface Pro 5 Screen Replacement: passo 13, imagem 2 %32 Microsoft Surface Pro 5 Screen Replacement: passo 13, imagem 3 %32
    • Once you cut the adhesive over the antennas (8.5 inches, or 22 cm, away from the left edge), slide the pick the rest of the way along the top edge of the surface and round the top right corner to slice through any remaining adhesive.
  14. Microsoft Surface Pro 5 Screen Replacement, Open the Surface: passo 14, imagem 1 %32 Microsoft Surface Pro 5 Screen Replacement, Open the Surface: passo 14, imagem 2 %32 Microsoft Surface Pro 5 Screen Replacement, Open the Surface: passo 14, imagem 3 %32
    • Very slowly lift the screen assembly away from the Surface case. If you encounter any resistance, stop and check that all the adhesive is separated.
    • Do not remove the screen yet. It is still connected to the motherboard by two cables.
    • Use an opening pick to cut through any remaining adhesive.
    • The flash lens may fall out of the Surface case. Keep track of the lens and return it to its cutout in the case during reassembly.
  15. Microsoft Surface Pro 5 Screen Replacement: passo 15, imagem 1 %32 Microsoft Surface Pro 5 Screen Replacement: passo 15, imagem 2 %32 Microsoft Surface Pro 5 Screen Replacement: passo 15, imagem 3 %32
    • Lift the top of the screen assembly away from the case while sliding the bottom of the screen closer to the motherboard display connectors.
    • Gently lay the screen down on the case with the connectors facing up. Take care to avoid creasing the display cables.
    No llega el cable derecho de la pantalla, al voltear la Tablet y este se romperá, lo ideal sera levantar la pantalla un poco y desconectar el cable de la tablet no de la pantalla.
    Francisco Arocas Cases - Responder
  16. Microsoft Surface Pro 5 Screen Replacement, Disconnect the screen: passo 16, imagem 1 %32 Microsoft Surface Pro 5 Screen Replacement, Disconnect the screen: passo 16, imagem 2 %32
    • Use an opening pick to pry up one edge of the EMI shield covering the display board.
    • Repeat this procedure at different points around the shield until it is free.
    • Try not to deform the shield too much—you will need to reinstall it during reassembly.
    I had better results using the black spudger to free the shields without damaging them.
  17. Microsoft Surface Pro 5 Screen Replacement: passo 17, imagem 1 %32
    • Lift the EMI shield away from the display board and remove it.
  18. Microsoft Surface Pro 5 Screen Replacement: passo 18, imagem 1 %32 Microsoft Surface Pro 5 Screen Replacement: passo 18, imagem 2 %32
    • Use the flat end of a spudger to pry the display interconnect cable straight up and out of its socket on the board.
  19. Microsoft Surface Pro 5 Screen Replacement: passo 19, imagem 1 %32 Microsoft Surface Pro 5 Screen Replacement: passo 19, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Insert one point of a pair of pointed tweezers into a gap in the edge of the EMI shield covering the digitizer connector.
    • Use the tweezers to pry the EMI shield away from the display as much as you can without bending it.
    • Repeat this procedure at different points around the shield until it is free. Remove the shield.
  20. Microsoft Surface Pro 5 Screen Replacement: passo 20, imagem 1 %32
    • Pull the rest of the shield off of the digitizer connector and remove it.
  21. Microsoft Surface Pro 5 Screen Replacement: passo 21, imagem 1 %32 Microsoft Surface Pro 5 Screen Replacement: passo 21, imagem 2 %32
    • Use the tip of a spudger to pry the digitizer connector straight up and out of its socket on the screen.
  22. Microsoft Surface Pro 5 Screen Replacement: passo 22, imagem 1 %32
    • Remove the screen assembly from the Surface.
    • During reassembly, pause here and follow this guide to replace the screen adhesive.
  23. Microsoft Surface Pro 5 Screen Replacement, Disconnect the display board: passo 23, imagem 1 %32 Microsoft Surface Pro 5 Screen Replacement, Disconnect the display board: passo 23, imagem 2 %32 Microsoft Surface Pro 5 Screen Replacement, Disconnect the display board: passo 23, imagem 3 %32
    • Use a spudger to flip up the small locking flaps on the display cable ZIF connectors.
  24. Microsoft Surface Pro 5 Screen Replacement: passo 24, imagem 1 %32 Microsoft Surface Pro 5 Screen Replacement: passo 24, imagem 2 %32 Microsoft Surface Pro 5 Screen Replacement: passo 24, imagem 3 %32
    • Use tweezers to slide the display cables straight out of their sockets on the display board.
  25. Microsoft Surface Pro 5 Screen Replacement, Remove the display board: passo 25, imagem 1 %32 Microsoft Surface Pro 5 Screen Replacement, Remove the display board: passo 25, imagem 2 %32 Microsoft Surface Pro 5 Screen Replacement, Remove the display board: passo 25, imagem 3 %32
    • Slide an opening pick under the display board to separate the adhesive holding it onto the back of the screen.
  26. Microsoft Surface Pro 5 Screen Replacement: passo 26, imagem 1 %32
    Tesa 61395 Tape
    $5.99
    • Remove the display board.
    • During reassembly, use a strong double-sided tape or a precut adhesive card to secure the display board. Clean off the old adhesive before applying new adhesive.
    • To ensure correct positioning, plug in both display connectors before adhering the board to the display.
  27. Microsoft Surface Pro 5 Screen Replacement: passo 27, imagem 1 %32
    • Only the screen remains.
    Note, on the flex connectors of the new screen are blue strips of protective plastic covering factory applied conductive adhesive. These must be removed and the adhesive must bond to the display board in order for the touch screen digitizer to function reliably.
Conclusão
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for troubleshooting help.
41 outras pessoas executaram este guia.
Sam Omiotek
Membro desde: 02/25/19
83.744 Reputação
Autoria de 290 guias
7 comentários
These instructions are very detailed. I followed them exactly. For the most part, they are great. Unfortunately, I bricked the original screen during removal process. After successfully removing the old screen without damaging the glass, I noticed that I had cut through one of the LCD screen connectors at the bottom left of the screen. The ifixit instructions on screen removal depicts this area as a "safe zone". It states "these areas only contain adhesive and are safe to cut." It does mention to avoid inserting the removal pick beyond the black screen bezel. Unfortunately, wires to the LCD screen, at least on my screen, extended a few mm into the black bezel area and were damaged by the removal pick. Therefore, the lower edge of the screen is not completely a "safe zone". Since the adhesive does not extend beyond about half way into the black bezel, I would recommend not inserting the pick more than half way into the black bezel, at least along the bottom edge.
Angelo Petropolis - Responder
I just had the same experience :(
Dmitry Matiouchenko - Responder
Moin, kann mir einer sagen, wo ich einen guten ersatz bildschirm für das 7 pro bekomme. die range geht ja von 84 bis weit über 400euro. hatte 1 aus italien für 104 gekauft, da geht der touch nicht und es wird gelegentlich dunkel und dann später geht es wieder und am unterern rand gibt es verfärbungen, je wärmer es ist ? wer billig kauft kauf 2x. nur wer sagt das die 400 euro display nicht auch mist sind....
Bo Chris Zen - Responder
Great instructions. Just finished the 7 hour replacement successfully. Original screen was removed without damage aside from one lcd screen connector on bottom left corner (Mentioned in earlier comments). Watch this area. Very very easy to ruin these cables.
Cameron - Responder
As the previous commenters say, DO NOT INSERT THE PICK MORE THAN HALF WAY NEAR WHERE THE RIBBON CABLES ARE! Roll the pick here, just as where the antennas are.
Bill - Responder
I just completed this repair with an entirely cracked screen and no prior tech repair experience, so here is my advice for anyone in a similar situation:
- It was better for me to use a hairdryer rather than the iopener - the heat didn't transfer well enough.
-The plastic pick will not slide easily no matter how heated the adhesive is (if your screen is cracked into small sections on the edges). Use a razor blade and be extra careful.
-Be prepared to spend a few hours on the screen removal alone.
-The cables that you had to snap out go directly onto their part (lay flat and press down). Be gentle at first so you don't mess them up if they are positioned wrong.
-When removing the adhesive on the 'antennas', I was very gentle and still punctured them once or twice. It doesn't seem to have any effect on the device working.
-Refer to the adhesive layout on the adhesive replacement guide (step 1, 3rd picture) rather than the general guide for more accuracy.
-I used a flat screwdriver to remove the adhesive
GLHF!
jd kornuto - Responder
Also, the metal frame was bent in the top right corner in my case, so the new screen wouldn't lay flat. I tried to preserve it at first, so - prying using screwdrivers, hitting a screwdriver with a hammer to push it out, and chipping + prying with needlenose pliers - none of this worked. I ended up using a dremel-like tool with a fine tip and grinding it down little by little until the screen would fit right, which worked perfectly (of course it's a minor cosmetic defect, but I don't care)
TLDR; if the case's frame is bent + preventing your new screen from fitting, drilling/grinding it down may be easier and work better rather than trying to bend it back
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 21
Últimos 7 dias: 104
Últimos 30 dias: 461
Duração total: 53,248
