Ir para o conteúdo principal
Micro-USB Port Replacement
O que você precisa
  1. Micro-USB Port Replacement, Back Plate: passo 1, imagem 1 %32 Micro-USB Port Replacement, Back Plate: passo 1, imagem 2 %32
    • Unscrew the four 3.4 mm flat head screws
    Pergunte ao FixBot
    Comentar
  2. Micro-USB Port Replacement: passo 2, imagem 1 %32
    • Carefully lift the back plate off the watch. You will notice a lithium battery and rubber gasket attached to the back plate.
    Pergunte ao FixBot
    Comentar
  3. Micro-USB Port Replacement, Lithium Battery: passo 3, imagem 1 %32
    • If not replacing lithium battery, skip down two steps.
    • Using the plastic removal tool, pry the battery from the backing plate. The battery is simply attached with glue.
    Pergunte ao FixBot
    Comentar
  4. Micro-USB Port Replacement: passo 4, imagem 1 %32
    • Desolder the battery connections from the motherboard. Learn how to solder components here!
    Pergunte ao FixBot
    Comentar
  5. Micro-USB Port Replacement, Motherboard: passo 5, imagem 1 %32
    • Use PH00 screw driver to remove two 2.4mm Phillips head screws.
    Pergunte ao FixBot
    Comentar
  6. Micro-USB Port Replacement: passo 6, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Use a spudger or tweezers to remove a white sticker that covers a Phillips head screw.
    Pergunte ao FixBot
    Comentar
  7. Micro-USB Port Replacement: passo 7, imagem 1 %32
    • Use PH00 screwdriver to remove 5.2mm Phillips head screw
    Pergunte ao FixBot
    Comentar
  8. Micro-USB Port Replacement: passo 8, imagem 1 %32 Micro-USB Port Replacement: passo 8, imagem 2 %32 Micro-USB Port Replacement: passo 8, imagem 3 %32
    • Use ESD safe tweezers to remove the gold ribbon cable.
    • This will expose a second 5.2mm Phillips head screw that can be removed with a PH00 screwdriver.
    Pergunte ao FixBot
    Comentar
  9. Micro-USB Port Replacement: passo 9, imagem 1 %32 Micro-USB Port Replacement: passo 9, imagem 2 %32
    • Use a spudger to gently pry on the motherboard towards the top of the watch, being towards the 12 o'clock position to loosen the motherboard.
    • You can now access the parts and pieces on the bottom of, and below the motherboard.
    Pergunte ao FixBot
    Comentar
  10. Micro-USB Port Replacement, Micro-USB Port: passo 10, imagem 1 %32
    • Locate the four main soldering points marked in red.
    • Be aware of the five additional soldered pins marked by the blue arrow.
    Pergunte ao FixBot
    Comentar
  11. Micro-USB Port Replacement: passo 11, imagem 1 %32 Micro-USB Port Replacement: passo 11, imagem 2 %32 Micro-USB Port Replacement: passo 11, imagem 3 %32
    • Begin to desolder the points pointed out in the last step.
    • Use the soldering wick to help remove the solder.
    Pergunte ao FixBot
    Comentar
Conclusão
3 outras pessoas executaram este guia.
Equipe
IUPUI, Team 3-3, Baechle Fall 2016 Membro de IUPUI, Team 3-3, Baechle Fall 2016
IUPUI-BAECHLE-F16S3G3
4 Membros
Autoria de 8 guias
1Comentário do guia
I want to know that what I have to do if want to replace the lithium battery with usb direct powered device.
amupis232389 - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 13
Últimos 30 dias: 78
Ao todo: 18,334
