O que você precisa
Using the plastic removal tool, pry the battery from the backing plate. The battery is simply attached with glue.
Locate the four main soldering points marked in red.
Be aware of the five additional soldered pins marked by the blue arrow.
3 outras pessoas executaram este guia.
1Comentário do guia
I want to know that what I have to do if want to replace the lithium battery with usb direct powered device.
