Ir para o conteúdo principal
Meta Quest 2 Eyepiece Trim Replacement
O que você precisa
  1. Meta Quest 2 Eyepiece Trim Replacement, Power off your Meta Quest 2: passo 1, imagem 1 %32
    • Hold the power button for three seconds to fully turn off your headset.
    • You'll hear a power down chime, and the LED next to the power button will turn off.
  2. Meta Quest 2 Eyepiece Trim Replacement, Remove the facial interface: passo 2, imagem 1 %32 Meta Quest 2 Eyepiece Trim Replacement, Remove the facial interface: passo 2, imagem 2 %32
    • Grasp and pull on the nose section of the facial interface to unclip it from the headset.
  3. Meta Quest 2 Eyepiece Trim Replacement: passo 3, imagem 1 %32 Meta Quest 2 Eyepiece Trim Replacement: passo 3, imagem 2 %32
    • Grasp and pull on the top section of the facial interface to unclip it from the headset.
  4. Meta Quest 2 Eyepiece Trim Replacement: passo 4, imagem 1 %32
    • Remove the facial interface.
    • During reassembly, align the facial interface to the headset and use your fingers to press along the perimeter to clip it back in.
  5. Meta Quest 2 Eyepiece Trim Replacement, Unclip the side straps: passo 5, imagem 1 %32 Meta Quest 2 Eyepiece Trim Replacement, Unclip the side straps: passo 5, imagem 2 %32 Meta Quest 2 Eyepiece Trim Replacement, Unclip the side straps: passo 5, imagem 3 %32
    • Use your fingers to grasp the right strap near the headset.
    • Peel the right strap away from the headset arm to unclip it.
  6. Meta Quest 2 Eyepiece Trim Replacement: passo 6, imagem 1 %32 Meta Quest 2 Eyepiece Trim Replacement: passo 6, imagem 2 %32
    • Repeat the procedure to peel the left strap away from the arm to unclip it.
  7. Meta Quest 2 Eyepiece Trim Replacement, Remove the top strap: passo 7, imagem 1 %32 Meta Quest 2 Eyepiece Trim Replacement, Remove the top strap: passo 7, imagem 2 %32
    • Separate the hook and loop strip on the top strap.
  8. Meta Quest 2 Eyepiece Trim Replacement, Remove the head strap: passo 8, imagem 1 %32 Meta Quest 2 Eyepiece Trim Replacement, Remove the head strap: passo 8, imagem 2 %32
    • Unthread the top strap from its bracket.
    • Remove the head strap.
  9. Meta Quest 2 Eyepiece Trim Replacement, Remove the eyepiece trim screws: passo 9, imagem 1 %32 Meta Quest 2 Eyepiece Trim Replacement, Remove the eyepiece trim screws: passo 9, imagem 2 %32
    • Use a Torx T2 driver to remove the six 3.5 mm‑long screws securing the eyepiece trim.
  10. Meta Quest 2 Eyepiece Trim Replacement, Release the eyepiece trim clips: passo 10, imagem 1 %32 Meta Quest 2 Eyepiece Trim Replacement, Release the eyepiece trim clips: passo 10, imagem 2 %32
    • Insert an opening pick into the seam between the eyepiece trim and white outer shell, near the nose cutout.
  11. Meta Quest 2 Eyepiece Trim Replacement: passo 11, imagem 1 %32 Meta Quest 2 Eyepiece Trim Replacement: passo 11, imagem 2 %32 Meta Quest 2 Eyepiece Trim Replacement: passo 11, imagem 3 %32
    • Slide the opening pick to the right along the seam to release the clips securing the eyepiece trim.
    • Pry with the opening pick to release the clips securing the right side of the eyepiece trim.
    • Leave the opening pick in the seam to prevent the clips from reengaging.
  12. Meta Quest 2 Eyepiece Trim Replacement: passo 12, imagem 1 %32 Meta Quest 2 Eyepiece Trim Replacement: passo 12, imagem 2 %32 Meta Quest 2 Eyepiece Trim Replacement: passo 12, imagem 3 %32
    • Repeat the prying procedure along the left edge to release the clips securing the eyepiece trim.
    • During reassembly, press your fingers along the perimeter of the eyepiece trim to clip it back in place.
  13. Meta Quest 2 Eyepiece Trim Replacement, Reposition the eyepiece trim: passo 13, imagem 1 %32 Meta Quest 2 Eyepiece Trim Replacement, Reposition the eyepiece trim: passo 13, imagem 2 %32 Meta Quest 2 Eyepiece Trim Replacement, Reposition the eyepiece trim: passo 13, imagem 3 %32
    • Don’t try to fully remove the eyepiece trim in this step. It’s still connected to the headset by a short cable.
    • Lift the eyepiece trim slightly and tilt it towards the top edge of the headset.
    • Set the trim down on your work surface, making sure not to strain the cable.
  14. Meta Quest 2 Eyepiece Trim Replacement, Disconnect the face sensor: passo 14, imagem 1 %32 Meta Quest 2 Eyepiece Trim Replacement, Disconnect the face sensor: passo 14, imagem 2 %32 Meta Quest 2 Eyepiece Trim Replacement, Disconnect the face sensor: passo 14, imagem 3 %32
    • Use the point of a spudger to flip open the black lock tab on the ZIF connector securing the face sensor cable.
  15. Meta Quest 2 Eyepiece Trim Replacement: passo 15, imagem 1 %32 Meta Quest 2 Eyepiece Trim Replacement: passo 15, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Use tweezers to pull the face sensor cable out of the ZIF connector.
  16. Meta Quest 2 Eyepiece Trim Replacement, Remove the eyepiece trim: passo 16, imagem 1 %32
    • Remove the eyepiece trim.
  17. Meta Quest 2 Eyepiece Trim Replacement, Reassembly note: passo 17, imagem 1 %32 Meta Quest 2 Eyepiece Trim Replacement, Reassembly note: passo 17, imagem 2 %32
    • During reassembly:
    • Make sure the lens spacing matches the spacing indicator. This allows the indicator peg to sit correctly in its notch.
    • If the lens spacing doesn't match the indicator, manually adjust the lens with your fingers.
  18. Meta Quest 2 Eyepiece Trim Replacement, Reassembly note: passo 18, imagem 1 %32 Meta Quest 2 Eyepiece Trim Replacement, Reassembly note: passo 18, imagem 2 %32 Meta Quest 2 Eyepiece Trim Replacement, Reassembly note: passo 18, imagem 3 %32
    • During reassembly, the face sensor cable can be tricky to connect. Follow these tips to connect the cable:
    • Thread your fingers through the eyepiece trim’s eyeholes and grasp the edges of the sensor cable.
    • Slide the sensor cable into the socket until the first set of tabs rests in the socket. This should flip the lock tab down partially.
    • Use a spudger to press the lock tab down towards the cable to lock it in place.
Conclusão
Arthur Shi
Membro desde: 01/03/18
285.574 Reputação
Autoria de 588 guias
Equipe
iFixit Membro de iFixit
Staff
120 Membros
Autoria de 20.302 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 58
Ao todo: 1,193
