Ir para o conteúdo principal
Marshall Stanmore II Tweeter Assembly Replacement
O que você precisa
  1. Marshall Stanmore II Tweeter Assembly Replacement, Rear Panel: passo 1, imagem 1 %32 Marshall Stanmore II Tweeter Assembly Replacement, Rear Panel: passo 1, imagem 2 %32
    • Turn off the device and unplug the cable from the wall and the speaker.
    • Lay the speaker with the back panel facing up on a flat, stable work surface.
    Pergunte ao FixBot
    Comentar
  2. Marshall Stanmore II Tweeter Assembly Replacement: passo 2, imagem 1 %32 Marshall Stanmore II Tweeter Assembly Replacement: passo 2, imagem 2 %32
    • Use a Phillips #2 screwdriver to remove the ten 20.5 mm screws that secure the rear panel to the chassis.
    Pergunte ao FixBot
    Comentar
  3. Marshall Stanmore II Tweeter Assembly Replacement: passo 3, imagem 1 %32 Marshall Stanmore II Tweeter Assembly Replacement: passo 3, imagem 2 %32
    • Carefully lift the rear panel and let it rest on an object, like a stack of books, to avoid straining the cables.
    • Do not attempt to fully remove the panel, as this will damage the connections inside.
    Pergunte ao FixBot
    Comentar
  4. Marshall Stanmore II Tweeter Assembly Replacement, Tweeter Assembly: passo 4, imagem 1 %32 Marshall Stanmore II Tweeter Assembly Replacement, Tweeter Assembly: passo 4, imagem 2 %32
    • Carefully pull back the translucent plastic sheathing on the two silver tweeter connectors.
    Pergunte ao FixBot
    Comentar
  5. Marshall Stanmore II Tweeter Assembly Replacement: passo 5, imagem 1 %32 Marshall Stanmore II Tweeter Assembly Replacement: passo 5, imagem 2 %32 Marshall Stanmore II Tweeter Assembly Replacement: passo 5, imagem 3 %32
    • Using your fingernail or tweezers, apply precise pressure to the small latch in the middle of the connector and gently pull upwards to disconnect the connector.
    • Repeat for the second connector.
    Pergunte ao FixBot
    Comentar
  6. Marshall Stanmore II Tweeter Assembly Replacement: passo 6, imagem 1 %32 Marshall Stanmore II Tweeter Assembly Replacement: passo 6, imagem 2 %32
    • Use a Torx T20 screwdriver to remove the three 20.5 mm screws that secure the tweeter.
    • Lift the tweeter assembly from its housing.
    Pergunte ao FixBot
    Comentar
  7. Marshall Stanmore II Tweeter Assembly Replacement: passo 7, imagem 1 %32
    • The felt seal is removable. If there is no seal on the tweeter, it may be stuck to the cutout on the speaker frame.
    • Repeat steps 4-6 to remove the second tweeter if necessary.
    Pergunte ao FixBot
    Comentar
Conclusão
1Comentário do guia
Do you know the tweeter spec? Or similar brand to install?
Leonardo Hernández - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 15
Últimos 30 dias: 44
Ao todo: 802
