Ir para o conteúdo principal
Marshall Stanmore II Subwoofer Assembly Replacement
O que você precisa
  1. Marshall Stanmore II Subwoofer Assembly Replacement, Rear Panel: passo 1, imagem 1 %32 Marshall Stanmore II Subwoofer Assembly Replacement, Rear Panel: passo 1, imagem 2 %32
    • Turn off the device and unplug the cable from the wall and the speaker.
    • Lay the speaker with the back panel facing up on a flat, stable work surface.
    Pergunte ao FixBot
    Comentar
  2. Marshall Stanmore II Subwoofer Assembly Replacement: passo 2, imagem 1 %32 Marshall Stanmore II Subwoofer Assembly Replacement: passo 2, imagem 2 %32
    • Use a Phillips #2 screwdriver to remove the ten 20.5 mm screws that secure the rear panel to the chassis.
    Pergunte ao FixBot
    Comentar
  3. Marshall Stanmore II Subwoofer Assembly Replacement: passo 3, imagem 1 %32 Marshall Stanmore II Subwoofer Assembly Replacement: passo 3, imagem 2 %32
    • Carefully lift the rear panel and let it rest on an object, like a stack of books, to avoid straining the cables.
    • Do not attempt to fully remove the panel, as this will damage the connections inside.
    Pergunte ao FixBot
    Comentar
  4. Marshall Stanmore II Subwoofer Assembly Replacement, Subwoofer Assembly: passo 4, imagem 1 %32 Marshall Stanmore II Subwoofer Assembly Replacement, Subwoofer Assembly: passo 4, imagem 2 %32 Marshall Stanmore II Subwoofer Assembly Replacement, Subwoofer Assembly: passo 4, imagem 3 %32
    • Pull back the clear sheaths on the end of each wire to expose the terminals.
    • Using a pair of tweezers, or your fingernail, depress the small latch and gently pull the wire off of the metal tabs.
    • Failure to press the latch while pulling could damage the subwoofer and/or wires.
    Pergunte ao FixBot
    Comentar
  5. Marshall Stanmore II Subwoofer Assembly Replacement: passo 5, imagem 1 %32
    • Remove the six 20.5 mm T20 Torx screws that secure the subwoofer to the housing.
    • The subwoofer assembly contains a very strong magnet, so the screwdriver and screws may occasionally stick to the side of the assembly.
    Pergunte ao FixBot
    Comentar
  6. Marshall Stanmore II Subwoofer Assembly Replacement: passo 6, imagem 1 %32
    • Carefully lift the subwoofer assembly away from the housing.
    Pergunte ao FixBot
    Comentar
  7. Marshall Stanmore II Subwoofer Assembly Replacement: passo 7, imagem 1 %32
    • Optional: Inspect the felt gasket on the speaker frame for any tears or foreign material.
    Pergunte ao FixBot
    Comentar
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 9
Últimos 30 dias: 61
Ao todo: 1,332
