Ir para o conteúdo principal
Marshall Stanmore II Power Switch Replacement
O que você precisa
  1. Marshall Stanmore II Power Switch Replacement, Rear Panel: passo 1, imagem 1 %32 Marshall Stanmore II Power Switch Replacement, Rear Panel: passo 1, imagem 2 %32
    • Turn off the device and unplug the cable from the wall and the speaker.
    • Lay the speaker with the back panel facing up on a flat, stable work surface.
    Pergunte ao FixBot
    Comentar
  2. Marshall Stanmore II Power Switch Replacement: passo 2, imagem 1 %32 Marshall Stanmore II Power Switch Replacement: passo 2, imagem 2 %32
    • Use a Phillips #2 screwdriver to remove the ten 20.5 mm screws that secure the rear panel to the chassis.
    Pergunte ao FixBot
    Comentar
  3. Marshall Stanmore II Power Switch Replacement: passo 3, imagem 1 %32 Marshall Stanmore II Power Switch Replacement: passo 3, imagem 2 %32
    • Carefully lift the rear panel and let it rest on an object, like a stack of books, to avoid straining the cables.
    • Do not attempt to fully remove the panel, as this will damage the connections inside.
    Pergunte ao FixBot
    Comentar
  4. Marshall Stanmore II Power Switch Replacement, Power Switch: passo 4, imagem 1 %32 Marshall Stanmore II Power Switch Replacement, Power Switch: passo 4, imagem 2 %32 Marshall Stanmore II Power Switch Replacement, Power Switch: passo 4, imagem 3 %32
    • Locate the Power Switch PCB on the left-hand side above the subwoofer.
    • Use a Phillips #2 screwdriver to remove the two 10 mm screws that secure the PCB.
    • Because the space inside is somewhat cramped, consider using the iFixit 150 mm Flex Extension included in the iFixit Pro Tech Toolkit.
    Pergunte ao FixBot
    Comentar
  5. Marshall Stanmore II Power Switch Replacement: passo 5, imagem 1 %32 Marshall Stanmore II Power Switch Replacement: passo 5, imagem 2 %32
    • Locate the PCB's black wire connector and gently disconnect it.
    • Do not pull on the wires.
    Pergunte ao FixBot
    Comentar
  6. Marshall Stanmore II Power Switch Replacement: passo 6, imagem 1 %32 Marshall Stanmore II Power Switch Replacement: passo 6, imagem 2 %32 Marshall Stanmore II Power Switch Replacement: passo 6, imagem 3 %32
    • Pull the PCB out of the mount.
    • Take care not to damage the rubber seal surrounding the switch base as depicted in picture two.
    • Rocking the PCB back and forth while pulling may help remove the module.
    Pergunte ao FixBot
    Comentar
Conclusão
3 outras pessoas executaram este guia.
3Comentários do guia
Hellooooo very good but were did you fint the eplace the power switch ?
Fred - Responder Compartilhar
Where can buy on /off switch ?
Choi Kee - Responder Compartilhar
On/off switch bar is broken
Comentar
Visualizações:
Últimas 24 horas: 12
Últimos 7 dias: 33
Últimos 30 dias: 114
Ao todo: 2,879
