Ir para o conteúdo principal
Making a low cost photography light stand
O que você precisa
  1. Making a low cost photography light stand, Unplug the lamp: passo 1, imagem 1 %32
    • Before disassembling on the lamp, it MUST be unplugged!
  2. Making a low cost photography light stand, Remove the lightbulb: passo 2, imagem 1 %32 Making a low cost photography light stand, Remove the lightbulb: passo 2, imagem 2 %32 Making a low cost photography light stand, Remove the lightbulb: passo 2, imagem 3 %32
    • If the bulb is worth keeping, this can be reused.
    • If the lamp has a lightbulb installed, remove it from the lamp.
  3. Making a low cost photography light stand, Remove the socket cover: passo 3, imagem 1 %32 Making a low cost photography light stand, Remove the socket cover: passo 3, imagem 2 %32 Making a low cost photography light stand, Remove the socket cover: passo 3, imagem 3 %32
    • MOST LAMPS WILL BE SIMILAR, but designs can vary.
    • Remove the switch handle. Note: While this can be optional, it was required on this lamp. If it looks tied into something, it probably has to be removed.
    • Remove the socket cover. Once removed, remove the bulb socket.
  4. Making a low cost photography light stand, Remove the bulb socket: passo 4, imagem 1 %32 Making a low cost photography light stand, Remove the bulb socket: passo 4, imagem 2 %32
    • Sockets that hold the cord in with a press-fit design are hard to reuse by design. Unless you can depress the cord, cut the cord at the socket and discard the bulb socket.
    • After removing the plastic cover and switch, remove the bulb socket with a Phillips #2 screwdriver. If your socket is press fit, these are generally not reusable. Cut the cord unless you can pull the cord and not compromise the socket.
    • Discard any broken or unwanted components.
  5. Making a low cost photography light stand, Remove the cord: passo 5, imagem 1 %32 Making a low cost photography light stand, Remove the cord: passo 5, imagem 2 %32 Making a low cost photography light stand, Remove the cord: passo 5, imagem 3 %32
    • Keep the cord if it is in good shape. These are excellent to keep around to repair other lamps (or anything in need of a similar cord).
    • After removing the bulb socket, remove the power cord.
  6. Making a low cost photography light stand, Test the lamp and find a good clamp point: passo 6, imagem 1 %32
    • After gutting the lamp, find a good spot to clamp a workshop light on like the one shown. Additional changes like height reduction can also be done at this stage.
Linha de Chegada
Nick
Membro desde: 11/10/09
88.899 Reputação
Autoria de 49 guias
Equipe
Master Techs Membro de Master Techs
Community
Membros da 322
Autoria de 2.539 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 9
Últimos 30 dias: 13
Duração total: 456
