Ir para o conteúdo principal
Main Board Replacement
O que você precisa
  1. Main Board Replacement, Exterior Housing: passo 1, imagem 1 %32 Main Board Replacement, Exterior Housing: passo 1, imagem 2 %32 Main Board Replacement, Exterior Housing: passo 1, imagem 3 %32
    Ferramenta utilizada neste passo:
    iOpener
    $24.95
    • Pry the exterior housing off the iHome iP37. You may need extra leverage to do this.
    • Note: This step is the most difficult due to the way it is attached. The glue holding the exterior housing to the internals does not break easily. You may want to use iFixit's iOpener to soften the glue.
    • Note: The process is the same for both the upper half and the lower half. To identify the halves, look for these details: the upper half has a metal grid, and the lower half has buttons. If you are replacing any other components, pry off the lower half.
    Pergunte ao FixBot
    Comentar
  2. Main Board Replacement, Lower Half Casing: passo 2, imagem 1 %32 Main Board Replacement, Lower Half Casing: passo 2, imagem 2 %32 Main Board Replacement, Lower Half Casing: passo 2, imagem 3 %32
    • Remove these four 9 mm screws from the plastic casing; you will need a Phillips #2 driver to do this.
    • Remove the flanged 9 mm screw from the counterweight; you will need a Phillips #2 driver to do this.
    • Lift and remove the counterweight.
    Pergunte ao FixBot
    Comentar
  3. Main Board Replacement: passo 3, imagem 1 %32 Main Board Replacement: passo 3, imagem 2 %32 Main Board Replacement: passo 3, imagem 3 %32
    • Lift and remove the plastic casing.
    • Note: It is best to lift the casing starting from the side without the protruding 3.5mm audio port and power port.
    • Reminder: During this process, a rubber cover will likely be dislodged. Make sure to re-seat this cover on the small pegs before putting the plastic casing back on.
    Pergunte ao FixBot
    Comentar
  4. Main Board Replacement, Preliminary Main Board: passo 4, imagem 1 %32 Main Board Replacement, Preliminary Main Board: passo 4, imagem 2 %32
    • Remove the two 9 mm screws that hold the main printed circuit board onto the rest of the iP37; you will need a Phillips #2 driver to do this.
    Pergunte ao FixBot
    Comentar
  5. Main Board Replacement: passo 5, imagem 1 %32
    • Peel away the black tape covering the red wires that connect to the PCB.
    Pergunte ao FixBot
    Comentar
  6. Main Board Replacement: passo 6, imagem 1 %32
    • There is ribbon wiring under this PCB. Be careful not to damage it while removing the PCB.
    • Slowly lift the PCB away from the rest of the device
    • Remove the ribbon by first removing the brown insert piece from the connector on the button board
    • Pull the ribbon out of the connector on the button board by the blue tab.
    Pergunte ao FixBot
    Comentar
  7. Main Board Replacement: passo 7, imagem 1 %32
    • Carefully disconnect the white 11-pin connector from the main board.
    • Pull firmly on the connector and use a screwdriver to pry it slightly if necessary.
    Pergunte ao FixBot
    Comentar
  8. Main Board Replacement, Main Board: passo 8, imagem 1 %32
    • Peel away the tape holding down the wires between the main board and the DC power and 3.5 mm audio jack board.
    Pergunte ao FixBot
    Comentar
  9. Main Board Replacement: passo 9, imagem 1 %32
    • Remove the two 3-pin connectors from the DC power and 3.5 mm audio jack board.
    Pergunte ao FixBot
    Comentar
  10. Main Board Replacement: passo 10, imagem 1 %32
    • Remove the black tape holding down the four wires connecting the main board to the upper half of the device.
    Pergunte ao FixBot
    Comentar
  11. Main Board Replacement: passo 11, imagem 1 %32
    • Carefully peel away the black melted plastic that covers the connection points from the four wires to the main board.
    • Make sure not to pull any of the wires out. This will make soldering them back on later more difficult. To avoid this, it may be easier to peel the melted plastic away in small chunks.
    Pergunte ao FixBot
    Comentar
  12. Main Board Replacement: passo 12, imagem 1 %32
    • Desolder the two red and two black wires from the main board, which will completely free the main board from the rest of the assembly.
    • You can refer to iFixit's guide or this informative video for more information on soldering.
    Pergunte ao FixBot
    Comentar
Conclusão
Jackson McKay
Membro desde: 04/22/14
124 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 11-50, Amido Spring 2014 Membro de Cal Poly, Team 11-50, Amido Spring 2014
CPSU-AMIDO-S14S11G50
4 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 26
Ao todo: 941
