Introdução
Replacing the heat sink requires removal of the logic board and application of new thermal paste.
O que você precisa
Remove the following ten screws securing the lower case to the upper case:
Three 13.5 mm (14.1 mm) Phillips screws.
Seven 3 mm Phillips screws.
Remove the two 7.4 mm Tri-point screws securing the battery to the upper case.
Note: For certain repairs (e.g. hard drive), removing the battery is not necessary but it prevents any accidental shorting of electronics on the motherboard. If you do not remove the battery, please be careful as parts of the motherboard might be electrified.
Tilt the battery away from the logic board enough to access the battery cable connector.
Pull the battery cable connector away from its socket on the logic board and remove the battery from the upper case.
Charge it to 100%, and then keep charging it for at least 2 more hours. Next, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
Remove the three 3.4 mm T6 Torx screws securing the left fan to the logic board.
Remove the three T6 Torx screws securing the right fan to the upper case.
53 outras pessoas executaram este guia.
8 comentários
Hello guys!! Can you help me?
I have the same MacBook Pro 2010. I want to replace the thermal compound in it.
Can I use liquid metal??? I mean, does the heat sink have aluminium metal??
Try Gelid Solutions GC-Extreme or Arctic cooling 5, They worked very well for me
Hello!
I have a big problem with my 2010 Macbook Pro 15.
After i had done the whole procedure of pasta sink changing. I powered my Macbook Pro and it has changed everything.
It has been very very slow, it changed the Clock, the Calender, did not work mouse, just an outside bluetooth mouse. It has SSD, but it has been reall really slow. So, as it has changed the whole OS X system.
When i had done the sink changing, i have just powered on my Mac. But it is not working, as i mentioned above.
Any idea to solve this big problem?
Bests,
Adam
