Introdução
Removing the lower cover is the starting point for all repairs.
For your safety, drain your MacBook Pro's battery below 25% before you begin this procedure.
Power on your Mac and launch Terminal.
Copy and paste the following command (or type it exactly) into Terminal:
sudo nvram AutoBoot=%00
Press [return]. If prompted, enter your administrator password and press [return] again. Note: Your return key may also be labeled ⏎ or "enter."
sudo nvram AutoBoot=%03
Use a P5 Pentalobe driver to remove the six screws securing the lower case:
Two 6.2 mm screws
Four 3.4 mm screws
Apply a suction handle to the lower case near the front-center area of the MacBook Pro.
Lift the suction handle to create a slight gap between the lower case and the chassis.
Insert one corner of an opening pick into the space between the lower case and the chassis.
Slide the opening pick around the nearest corner and halfway up the side of the case.
Insert your opening pick once again under the front edge of the lower case, near one of the two centermost screw holes.
Give the pick a firm twist to pop free the third clip securing the lower case to the chassis.
Repeat this procedure near the other of the two centermost screw holes, popping the fourth clip free.
Remove the lower case.
Set it in place and align the sliding clips near the display hinge. Press down and slide the cover toward the hinge. It should stop sliding as the clips engage.
When the sliding clips are fully engaged and the lower case looks correctly aligned, press down firmly on the lower case to engage the four hidden clips underneath. You should feel and hear them snap into place.
9 outras pessoas concluíram este guia.
