Introdução
Use this guide to replace the upper case, which includes the keyboard. This procedure involves using adhesive remover to remove the battery. Do not reuse the battery after it has been removed, as doing so is a potential safety hazard. Replace it with a new battery.
iFixit adhesive remover is highly flammable. Perform this procedure in a well-ventilated area. Do not smoke or work near an open flame during this procedure.
To minimize risk of damage, turn on your MacBook and allow the battery to fully discharge before starting this procedure. A charged lithium-ion battery can create a dangerous and uncontrollable fire if accidentally punctured. If your battery is swollen, take extra precautions.
Some replacement upper case assemblies may include the trackpad and battery as well. In this case, skip steps 18 through 44.
This guide requires the removal of the heat sink. Don't forget to follow our thermal paste application guide before you reinstall your heat sink.
Remove the following ten screws securing the lower case to the upper case:
Two 2.3 mm P5 Pentalobe screws
Eight 3.0 mm P5 Pentalobe screws
Remove the two 2.1 mm T5 Torx screws securing the logic board end of the I/O board cable bracket.
Insert the tip of a spudger under the left speaker cable near the connector and lift it up out of its socket on the logic board.
Remove the five 3.7 mm T5 Torx screws securing the battery to the upper case.
Alternatively, if you are using the hot iOpener method, skip the following three steps.
Wear eye protection when handling and applying the adhesive remover. (Eye protection is included in your kit.)
Do not wear contact lenses without eye protection.
Protective gloves are also included in your kit. If you are concerned about skin irritation, put your gloves on now.
Repeat this procedure with the adjacent battery cell:
Apply a small amount of liquid adhesive remover under the battery cell, and wait 2-3 minutes for it to penetrate and soften the adhesive.
Alternatively, re-heat this section with your iOpener if needed.
Push a plastic card about an inch between the battery cell and the upper case, and slowly pry the cell up to separate all of the adhesive.
Repeat the above procedure to separate the two leftmost battery cells from the upper case.
Remember to apply a small amount of adhesive remover to each battery cell, and wait 2-3 minutes for it to penetrate and soften the adhesive.
Use a second plastic card to separate the two leftmost battery cells from the upper case.
To separate the adhesive securing the final two, middle battery cells, apply a few more drops of liquid adhesive remover (or your iOpener) to each cell.
It may help to elevate one side of your MacBook Pro a few inches so that the adhesive remover flows in the correct direction, underneath the battery cells. You can use a sturdy book or foam block to prop up one side of your MacBook Pro while you work.
Insert the card about an inch between the left-center battery cell and the upper case, separating the adhesive between the cell and the case.
Remove the battery.
With a little luck, you can slowly pull out each strip of adhesive with your fingers.
Otherwise, soak each section of adhesive with a bit of adhesive remover for 2-3 minutes, and then scrape it out with an opening pick or one of the other tools in your kit. This can take quite a bit of work, so be patient.
Mop up any remaining adhesive remover and give your MacBook Pro a few minutes to air dry.
Calibrate your newly installed battery: charge it to 100%, and keep charging it for at least 2 more hours. Unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
Place a reheated iOpener over the trackpad cover plate to soften the adhesive securing it to the upper case.
Grab the black plastic tab to flip the display cable connector open and pull it straight out of its socket on the logic board.
Pull in the direction of the cable, parallel to the logic board. Do not pull up.
Insert the tip of a spudger under each of the antenna cables near their connectors and pry up to disconnect them from the AirPort board.
Connect the long-sleeved cable to the center socket.
The short-sleeved cable connects next to the screw.
The remaining cable has no sleeve, and connects in the last empty socket, next to the fan.
20 outras pessoas concluíram este guia.
7 comentários
hey there! steps seem very useful, really hope that this will work. but what am i going to do after the replacement? now i “only“ know how to get to the upper case. is there any instruction for putting the mac book back together after replacing the upper case? would be thankful for that advice!
I have just done this repair now and it all went great with the help of this article. I purchased a second hand top case which had a battery, trackpad, keyboard, speakers and microphones still in tact and in good condition. This allows you to skip nearly 50% of the steps in this tutorial. Highly recommended to try and find something similar yourself. Slow and steady is definitely the way to do this repair and if you do that and use the right tools you will find the repair to be easy and painless. Best of luck to all.
Took a tad over 2 hours to do, including the screen. Have to remember to reset the SMC controller (Once repaired press Control, option, power button for 10 sec after shut down. Then hit power button again). I watched the cpu temp with Fanny to make sure the new thermal paste was applied correctly and used rubbing alcohol to do the cleaning.
Kudos on a great guide. Did what Mr. Davies did, saves a lot of heartache. Battery removals are not enjoyable one bit. Looked for a top case sub $60 with a low battery cycle count (250 and below),
Managed to get this done in about 2.5 hours, but I was able to skip some steps. Goal was replacing upper case assembly to get a working keyboard. I managed to replace the logic board without removing the heatsink, which was the only step I really wanted to avoid due to manual application of thermal paste as opposed to the dot method. I also managed to find an upper case replacement with only about 100 cycles on it and a working trackpad, so not having to replace the batteries or trackpad saved time and effort as well. Need to check temps just in case— and still need to test the I/O ports to be sure. But overall, great guide- very comprehensive. Just use the sections you need. FYI - if you’re planning on replacing the keyboard for this machine, plan on replacing the whole Upper Case Assembly. My understanding from others giving advice are that keys are riveted on and very difficult to replace. You’re better off swapping out the whole upper case.
Hi
I purchased by mistake a 2015 upper case for my 2014 Macbook Pro (both A1502)
Having dismantled the MBP I noticed that the trackpad is different therefore I ordered the proper model and ribbon cable
Will this installed (2015) upper case be compatible with my MBP 2014 ?
thanks
yann
