Ir para o conteúdo principal
MacBook Pro 13" 2022 (M2) Lower Case Replacement
O que você precisa
  1. MacBook Pro 13" 2022 (M2) Lower Case Replacement, Prepare your MacBook for disassembly: passo 1, imagem 1 %32 MacBook Pro 13" 2022 (M2) Lower Case Replacement, Prepare your MacBook for disassembly: passo 1, imagem 2 %32 MacBook Pro 13" 2022 (M2) Lower Case Replacement, Prepare your MacBook for disassembly: passo 1, imagem 3 %32
    • Allow your MacBook's battery to drain below 10% before starting this repair. A charged battery may catch fire if damaged during the repair.
    • Unplug all cables and fully shut down your MacBook.
    • Close the lid and flip your MacBook over. Keep the lid closed until you've physically disconnected the battery.
    • Opening the lid will power on your MacBook. If you're using macOS Big Sur v11.1 or earlier, disable this function using this guide.
  2. MacBook Pro 13" 2022 (M2) Lower Case Replacement, Unfasten the lower case: passo 2, imagem 1 %32
    Ferramenta utilizada nesse passo:
    FixMat
    $36.95
    Comprar
    • Use a P5 Pentalobe driver to remove the six screws securing the lower case:
    • Two 6.8 mm screws
    • Two 5.3 mm screws
    • Two 3.4 mm screws
  3. MacBook Pro 13" 2022 (M2) Lower Case Replacement, Separate the lower case: passo 3, imagem 1 %32 MacBook Pro 13" 2022 (M2) Lower Case Replacement, Separate the lower case: passo 3, imagem 2 %32
    • Apply a suction handle near the front edge of the lower case, between the screw holes.
    • Pull up on the suction handle to create a gap between the lower case and the frame.
  4. MacBook Pro 13" 2022 (M2) Lower Case Replacement, Release the left clips: passo 4, imagem 1 %32 MacBook Pro 13" 2022 (M2) Lower Case Replacement, Release the left clips: passo 4, imagem 2 %32 MacBook Pro 13" 2022 (M2) Lower Case Replacement, Release the left clips: passo 4, imagem 3 %32
    • Insert an opening pick between the lower case and the frame.
    • Slide the pick around the left corner to release the first set of clips.
    • You'll hear and feel a pop when each clip releases.
  5. MacBook Pro 13" 2022 (M2) Lower Case Replacement, Release the right clips: passo 5, imagem 1 %32 MacBook Pro 13" 2022 (M2) Lower Case Replacement, Release the right clips: passo 5, imagem 2 %32 MacBook Pro 13" 2022 (M2) Lower Case Replacement, Release the right clips: passo 5, imagem 3 %32
    • Slide your opening pick around the right corner to release the second set of clips securing the lower case.
  6. MacBook Pro 13" 2022 (M2) Lower Case Replacement, Pry the lower case up: passo 6, imagem 1 %32 MacBook Pro 13" 2022 (M2) Lower Case Replacement, Pry the lower case up: passo 6, imagem 2 %32 MacBook Pro 13" 2022 (M2) Lower Case Replacement, Pry the lower case up: passo 6, imagem 3 %32
    • Insert your opening pick between the lower case and the frame near the middle left screw hole.
    • Firmly twist the pick until the clip releases.
    • Repeat this procedure for the clip near the middle right screw hole.
  7. MacBook Pro 13" 2022 (M2) Lower Case Replacement, Release the remaining clips: passo 7, imagem 1 %32 MacBook Pro 13" 2022 (M2) Lower Case Replacement, Release the remaining clips: passo 7, imagem 2 %32 MacBook Pro 13" 2022 (M2) Lower Case Replacement, Release the remaining clips: passo 7, imagem 3 %32
    • Firmly pull the lower case away from the screen hinges to release the last clips securing it to the frame.
    • This motion requires significant force. Don't pull the lower case up, as you may bend the clips.
    • If it feels stuck, pull one corner at a time.
  8. MacBook Pro 13" 2022 (M2) Lower Case Replacement, Remove the lower case: passo 8, imagem 1 %32 MacBook Pro 13" 2022 (M2) Lower Case Replacement, Remove the lower case: passo 8, imagem 2 %32
    • Remove the lower case.
    • To reinstall the lower case:
    • Set it in place and align the sliding clips near the display hinges. Press down and slide the lower case toward the hinges.
    • Once the lower case is secured near the hinges, press down firmly to engage the remaining four clips.
    • You'll hear and feel a pop when each clip engages.
Conclusão
Repair didn’t go as planned? Try some basic troubleshooting or search our Answers community for help.
Clay Eickemeyer
Membro desde: 09/19/22
69.526 Reputação
Autoria de 453 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 141
Autoria de 17.895 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 8
Últimos 7 dias: 50
Últimos 30 dias: 179
Duração total: 1,806
