Ir para o conteúdo principal
MacBook Air 13" Early 2020 USB-C Board Replacement
O que você precisa
  1. MacBook Air 13" Early 2020 USB-C Board Replacement, Remove the screws securing the lower case: passo 1, imagem 1 %32
    Ferramenta utilizada neste passo:
    Magnetic Project Mat
    $19.95
    • Before starting this procedure, you should disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide to disable Auto Boot.
    • If your MacBook is running Big Sur v11.1 or later, disabling Auto Boot may not work. You can proceed normally, but make sure to disconnect the battery as soon as you're inside.
    • Completely power off and unplug your MacBook Air before you start. Close the display and flip the entire laptop upside-down.
    • Use a P5 driver to remove the following screws:
    • Two 7.9 mm screws
    • Two 7.1 mm screws
    • Six 2.6 mm screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your MacBook.
    P5 is also a PL4 (so confusing) - i like the wiha 26764 thanks to @mayer for this post. P5 pentalobe and 1.2 pentalobe screwdriver
    greg - Responder
  2. MacBook Air 13" Early 2020 USB-C Board Replacement, Remove the lower case: passo 2, imagem 1 %32 MacBook Air 13" Early 2020 USB-C Board Replacement, Remove the lower case: passo 2, imagem 2 %32 MacBook Air 13" Early 2020 USB-C Board Replacement, Remove the lower case: passo 2, imagem 3 %32
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
    • Remove the lower case.
    • To reinstall the lower case:
    • Set it in place and press firmly to engage the two hidden clips underneath. You should feel and hear them snap into place.
    When reassembling, the “snaps” are in the middle of the laptop (from top to bottom), and just to the left and right of center. I assumed it was near the hinge so it took a bit for me to hear the snaps.
    Laurie McCall - Responder
    Laurie, the two clips are outlined in the third photo of step two. Hope this helps—happy fixing!
    Carsten Frauenheim -
    What tool kit should I use for this?
    Lucas Lee - Responder
    the second picture is m1 air right?
    the antenna cable position does not match later picture
    Paul - Responder
  3. MacBook Air 13" Early 2020 USB-C Board Replacement, Disconnect the battery: passo 3, imagem 1 %32
    • Peel back the tape covering the battery connector enough to reveal the connector underneath.
    This image is incorrect correct for the A2179 EMC 3302 model, also doesn’t match the next image in this guide
    Steven Friar - Responder
    There is other guide for the model you reffer to, I was using that one until i realize it was different, this is the one you are looking for: MacBook Air 13" Retina Late 2020 (M1)
    Marco Rojas -
    I initially thought the image was incorrect, but I was just looking for the connector in the wrong place. This picture IS correct for the A2179 EMC 3302. Note that the connector is on the left side of the heat sink (the black thing with parallel ridges in the picture and on the computer), and the connector wires gather together towards the left the side of the computer, not the back. Note that "left side" assumes the Air is upside-down, with the hinge on the side farthest away from you (I'm not doing the "right speaker is on the left side because it's upside-down" thing that iFixit does in step 5).
    Bryan Gillson -
    How do you find out if you have a Retina Late or Retina Early model?
    Inji E - Responder
  4. MacBook Air 13" Early 2020 USB-C Board Replacement: passo 4, imagem 1 %32 MacBook Air 13" Early 2020 USB-C Board Replacement: passo 4, imagem 2 %32
    • Use a spudger to slide the battery connector parallel to the logic board and out of its socket on the logic board.
    It’s stuck can’t get it out
    Jeansceem Jeansceem - Responder
  5. MacBook Air 13" Early 2020 USB-C Board Replacement, Remove the USB-C board: passo 5, imagem 1 %32 MacBook Air 13" Early 2020 USB-C Board Replacement, Remove the USB-C board: passo 5, imagem 2 %32
    • Use a T3 Torx driver to remove the two 1.4 mm screws securing the USB-C connector cover.
    • Remove the USB-C connector cover.
  6. MacBook Air 13" Early 2020 USB-C Board Replacement: passo 6, imagem 1 %32 MacBook Air 13" Early 2020 USB-C Board Replacement: passo 6, imagem 2 %32
    • Use the flat end of a spudger to pry the USB-C cable connector up and out of its socket on the logic board.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  7. MacBook Air 13" Early 2020 USB-C Board Replacement: passo 7, imagem 1 %32
    • Use a T4 Torx driver to remove the two 2.9 mm screws securing the USB-C board.
  8. MacBook Air 13" Early 2020 USB-C Board Replacement: passo 8, imagem 1 %32
    • Use a pair of tweezers to remove the USB-C board.
    On the Early 2020 model at least, you will almost certainly have to loosen the logic board before you can do this step. This involves disconnecting the left speaker, and removing the two rightmost logic board screws. On the 2018 and 2019 models, this seems not to be necessary. If you have an early 2020 model and are trying these steps, don't force the USB-C connector out - loosen the logic board first. You don't have to remove it all the way.
    matt - Responder
Conclusão
8 outras pessoas executaram este guia.
Carsten Frauenheim
Membro desde: 03/10/20
136.384 Reputação
Autoria de 371 guias
Equipe
iFixit Membro de iFixit
Staff
118 Membros
Autoria de 19.623 guias
4 Guide Comments
Great guide and easy repair! My MacBook Air thought it was perpetually plugged in and would only charge from one of the USB C ports, this repair fixed it! I had a little scare when rebooting after the the fix, I either wasn’t pressing the power/touch ID button long enough or resetting the SMC (left shift, control, option, and power buttons) and holding the buttons until it booted worked. Not sure which did it.
Tyler - Responder
Thanks a lot, the repair guide was perfect ! It really took me 5mn.
My usb-c connector got corroded after I accidentally pulled some water on my computer. As by Tyler’s comment, my MBA was only working from one single port anymore and showed to be perpetually connected and in charge. I got the spare chip from AliExpress for 10€. Apple would have charged me for 400€…
Lastly, when booting for the 1st time after doing the repair, pressing the power button didn’t work and my MBA stayed off. I had to plug it to the charger and it then booted seamlessly.
Thanks again !
Faabio - Responder
Wish i could change out my USB port on my 2014 MacAir to USB-C
Shaun M. - Responder
The same experience as Fabio. The repair was simple and straight-forward and the machine wouldn't boot from the battery the first time. Once plugged into the charger it booted just fine and has booted off the battery as normal ever since.
Fixed my 1 dead USB port problem with very little hassle/cost. Just be prepared for the bowel clenching moment when it won't boot from the battery the first time.
Cary - Responder
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 44
Últimos 30 dias: 248
Ao todo: 9,392
