Introdução
Use this guide to replace the upper case, including the keyboard, of your MacBook Air 13" Early 2017.
O que você precisa
Ferramenta utilizada neste passo:P5 Pentalobe Screwdriver Retina MacBook Pro and Air$5.99
Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
Two 9 mm screws
Eight 2.6 mm screws
Grab the clear plastic pull tab attached to the battery connector and pull it parallel to the board toward the front edge of the Air.
Use the flat end of a spudger to pry the I/O board cable connector up out of its socket on the I/O board.
Use the tip of a spudger to carefully flip up the retaining flap on the fan cable ZIF socket.
Disconnect the I/O board by pulling its power cable away from its socket on the logic board.
Remove the following five screws securing the battery to the upper case:
Three 6.9 mm T5 Torx screws
Two 3.0 mm T5 Torx screws
Lift the battery from its edge nearest the logic board and remove it from the upper case.
Charge it to 100%, and then keep charging it for at least 2 more hours. Then, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
Grab the plastic pull tab secured to the display data cable lock and rotate it towards the top side of the computer.
Remove the inner two 5.6 mm T8 Torx screws securing the right display hinge to the upper case.
Use the flat end of a spudger to pry the left speaker off the adhesive securing it to the upper case.
Remove the left speaker from the upper case.
Use the tip of a spudger or your fingernail to flip up the retaining flap on the trackpad ribbon cable ZIF socket.
Pull the trackpad ribbon cable straight out of its socket toward the rear edge of the Air.
14 outras pessoas executaram este guia.
4Comentários do guia
Excellent guide. As there was no guide for mainboard replacement I used this one up to step 30, perhaps there should be a guide? The most difficult part for me was getting the rubber fan gasket to sit where it needed to during reassembly, perhaps a detail photo of this when the PCB is floating would be a benefit. I also had another small rubber piece come loose from somewhere and was unable to determine where it was supposed to live. It was about 1.5 cm long, and had an extruded channel in it, like perhaps it was supposed to protect and edge or a cable… seemed to fall off from somewhere on the LCD connector side of the board, but I don’t see it in any of the photos included and nothing was obvious.
I used this as a teardown and then in reverse a rebuild guide. My mac was water damaged and I replaced the logic board using this guide. And it worked! Thanks so much to the author
