Introdução
Faça um upgrade no seu disco rígido para aumentar a capacidade de armazenamento.
O que você precisa
Vídeo de Apresentação
Desligue o Mac mini, desconecte todos os cabos e vire-o.
Insira o Jimmy na fresta entre a carcaça superior de alumínio e a carcaça inferior de plástico.
O Jimmy deve atingir um limite a cerca de 10 mm de profundidade.
Pressione levemente os dois braços de retenção um contra o outro e levante a antena do AirPort para fora do seu pino.
Remova os dois parafusos Phillips que prendem a lateral do disco rígido à estrutura interna.
Remova os dois parafusos Phillips que prendem a parte inferior do disco rígido à estrutura interna.
Para a remontagem de seu dispositivo, siga estas instruções na ordem inversa.
548 outras pessoas executaram este guia.
Um agradecimento especial a esses tradutores:
100%
Translation Bot está nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
17Comentários do guia
The foam on the harddrive is attached with an adhesive tape - be careful to peel up the tape from the harddrive, rather than the foam from the tape.
I seemed to succeed - until I discovered my optical drive had broken. Disks do not mount, after some tries they eject. There was a LOT of dust inside my Mini, I think some got in the optical drive. A cleaning DVD and compressed gas didn't fix it. I wonder if it would be wise to seal the opening to the optical drive -- certainly before cleaning.
This was a failure for me, even though the memory and drive change went well.
Can't fault this guide.
* if you don't have a putty knife & you don't mind some scratches, a thin butter knife will do the trick for getting the case off.
*if you plan to replace hdd with an ssd - you may need to rejig some of the internal wires that run around the edges of the hdd/ssd: after I installed the ssd, and returned the wires to the tight track around the side and socket port end of the ssd, and turned the machine back on, there was a high pitch interference noises coming out the internal speaker every time the drive was active.
The solution: make sure the speaker wire isn't where it's *supposed* to be! There are three sets of wires, include the speaker pair. I reversed the positioning of these with respect to the SSD, i.e. I moved the speaker pair to be furthest away from the SSD, and *didn't* tuck them back in under the plastic lip beside the ssd connector port. I turned it back on, and no more high frequency whining whenever the drive is active
I upgraded my 2007 A1176 Mac Mini with a 2 TB M9T drive that I broke out of Seagate Backup Plus Ext. HD and increased my RAM from 2 GB to 3 GB! Success!
Be very careful with the audio cable removal the ZIF cable lock is VERY DELICATE!!!
